[Bio] / FigWebServices / pir.cgi Repository:
Log of /FigWebServices/pir.cgi
Links to mgrast_rel_2008_0917: (view) (download) (annotate)
Revision 1.33 - (view) (download) (annotate) - [select for diffs]
Mon Dec 5 19:12:12 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.32: +17 -0 lines
Diff to previous 1.32
add license words
Revision 1.32 - (view) (download) (annotate) - [select for diffs]
Thu Aug 4 22:25:12 2005 UTC (14 years, 8 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.31: +9 -9 lines
Diff to previous 1.31
fixing help links
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Fri Jun 10 16:43:27 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.30: +1 -1 lines
Diff to previous 1.30
minor changes to pir.cgi
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Thu May 5 03:16:54 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.29: +1 -1 lines
Diff to previous 1.29
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Fri Apr 8 20:43:32 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.28: +4 -3 lines
Diff to previous 1.28
Added creation of the download file from pir.cgi
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Fri Apr 8 20:22:23 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.27: +41 -4 lines
Diff to previous 1.27
changed tag/value pairs completely. Ooops!
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Thu Apr 7 20:25:13 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.26: +3 -2 lines
Diff to previous 1.26
correcting API.html
Thu Apr 7 19:16:10 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.25: +14 -5 lines
Diff to previous 1.25
many changes to key/value pairs to make them work
Sun Apr 3 20:42:24 2005 UTC (15 years ago) by redwards
Changes since 1.24: +3 -2 lines
Diff to previous 1.24
changes to pir interactions
Sun Apr 3 19:25:21 2005 UTC (15 years ago) by redwards
Changes since 1.23: +10 -11 lines
Diff to previous 1.23
Sun Apr 3 19:11:11 2005 UTC (15 years ago) by redwards
Changes since 1.22: +38 -53 lines
Diff to previous 1.22
Added a script to load pir superfamilies in the background. This will download all the data and install it. Changed pir.cgi to background this job as it takes a while.
Sun Apr 3 02:15:15 2005 UTC (15 years ago) by redwards
Changes since 1.21: +213 -37 lines
Diff to previous 1.21
changes to pir-seed interactions and new help page
Sat Mar 26 13:30:57 2005 UTC (15 years ago) by overbeek
Changes since 1.20: +6 -6 lines
Diff to previous 1.20
add uniprot ids/links on pir family comparison
Sat Feb 12 23:36:21 2005 UTC (15 years, 1 month ago) by redwards
Diff to previous 1.19
More changes to subsys_summary and converting pir.cgi popup menu to scroll list.
Sat Feb 12 06:54:29 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.18: +1 -0 lines
Diff to previous 1.18
add a title to pir.cgi
Sat Feb 12 04:08:00 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.17: +2 -1 lines
Diff to previous 1.17
Minor changes to pir.cgi and added subsystem_classification to FIG.pm
Sat Feb 12 02:48:28 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.16: +5 -5 lines
Diff to previous 1.16
more more changes to pir.cgi
Sat Feb 12 02:44:34 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.15: +8 -2 lines
Sat Feb 12 02:37:15 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.14: +1 -0 lines
Sat Feb 12 02:33:06 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.13: +1 -0 lines
Sat Feb 12 02:24:08 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.12: +3 -3 lines
Sat Feb 12 02:22:01 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.11: +13 -11 lines
Sat Feb 12 02:06:37 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.10: +4 -0 lines
Sat Feb 12 01:31:19 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.9: +9 -4 lines
Sat Feb 12 01:11:04 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.8: +26 -53 lines
more changes to pir.cgi to make it interactive
Sat Feb 12 00:36:39 2005 UTC (15 years, 1 month ago) by redwards
changes to pir.cgi to make tabulating things interactive
Sat Feb 12 00:19:33 2005 UTC (15 years, 1 month ago) by redwards
Sat Feb 12 00:06:15 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.5: +12 -3 lines
Fri Feb 11 23:53:37 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.4: +68 -4 lines
Tue Feb 8 00:42:36 2005 UTC (15 years, 1 month ago) by redwards
allow pir.cgi to ignore things without subsys links
Fri Feb 4 06:59:46 2005 UTC (15 years, 2 months ago) by redwards
Changes since 1.2: +0 -1 lines
more changes to genomebrowser.cgi to make it work really well
Sun Jan 30 17:16:57 2005 UTC (15 years, 2 months ago) by redwards
Changes since 1.1: +27 -22 lines
Changes to pir.cgi and subsys,cgi to allow linking between. Added a function in
subsys.cgi so that you can color the columns by tag/value pairs
Sat Jan 29 20:59:53 2005 UTC (15 years, 2 months ago) by redwards
Adding pir.cgi an interface between SEED and PIR. Provides some direct functionality, but
perhaps best called indirectly.
