[Bio] / FigWebServices / makewsdl.pl Repository:
Log of /FigWebServices/makewsdl.pl
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Mon Oct 29 20:42:43 2007 UTC (12 years, 7 months ago) by disz
Changes since 1.2: +0 -0 lines
Replaced after Rob delete
Revision 1.2
Thu Oct 25 22:21:28 2007 UTC (12 years, 7 months ago) by redwards
FILE REMOVED
changing the makewsdl script to a live cgi
Tue Oct 23 15:47:44 2007 UTC (12 years, 7 months ago) by disz
Diff to selected 1.3
generates wsdl from pod doc in fig_scripts_service.cgi
