[Bio] / FigWebServices / ma_to_tf_nr.cgi Repository:
Log of /FigWebServices/ma_to_tf_nr.cgi
Links to mgrast_dev_12152011: (view) (download) (annotate)
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Feb 9 04:30:58 2006 UTC (14 years, 1 month ago) by mkubal
Changes since 1.2: +120 -37 lines
with orpv
Mon Jan 30 21:35:40 2006 UTC (14 years, 2 months ago) by mkubal
Changes since 1.1: +90 -7 lines
with gene table
Fri Jan 20 16:14:37 2006 UTC (14 years, 2 months ago) by mkubal
Diff to selected 1.3
new
