[Bio] / FigWebServices / ma2sub.cgi Repository:
Log of /FigWebServices/ma2sub.cgi
Revision 1.6 - (view) (download) (annotate) - [selected]
Mon Dec 5 19:12:12 2005 UTC (14 years, 1 month ago) by olson
add license words
Wed Oct 12 21:03:16 2005 UTC (14 years, 3 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Mon Aug 1 16:29:22 2005 UTC (14 years, 5 months ago) by olson
Replace use of $FIG_Config::cgi_url with &FIG::cgi_url()
Sun Jul 24 22:08:58 2005 UTC (14 years, 5 months ago) by mkubal
Changes since 1.2: +26 -32 lines
1.3ma2sub
Sun Jul 24 21:49:33 2005 UTC (14 years, 5 months ago) by mkubal
1.4ma2sub
Sun Jul 24 19:49:15 2005 UTC (14 years, 5 months ago) by mkubal
Diff to selected 1.6
new ma2sub
