[Bio] / FigWebServices / lock_subsys.cgi Repository:
Log of /FigWebServices/lock_subsys.cgi
Links to mgrast_rel_2008_0919: (view) (download) (annotate)
Sat Dec 23 04:32:47 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.1: +48 -8 lines
allow selection of all roles/genomes for locking
Sat Dec 23 03:43:50 2006 UTC (13 years, 5 months ago) by overbeek
add lock_subsys.cgi
