[Bio] / FigWebServices / link.cgi Repository:
Log of /FigWebServices/link.cgi
Wed Feb 27 02:05:39 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.5: +16 -33 lines
Updated to direct users to the seed viewer.
Tue Apr 10 04:00:31 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.4: +39 -38 lines
Added documentation for the SOP support.
Thu Mar 15 19:19:30 2007 UTC (12 years, 9 months ago) by disz
Changes since 1.3: +14 -1 lines
Added SOP link
Wed Oct 25 21:06:09 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.2: +0 -10 lines
Wed Oct 25 21:03:07 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.1: +40 -24 lines
Enhanced to handle "nmpdr|" as an ID prefix.
Mon Oct 2 03:03:08 2006 UTC (13 years, 2 months ago) by parrello
Added to support external linking to protein pages.
