[Bio] / FigWebServices / kernel_xmlrpc.cgi Repository:
Log of /FigWebServices/kernel_xmlrpc.cgi
Links to rast_rel_2010_0827: (view) (download) (annotate)
Mon Jan 16 00:23:48 2006 UTC (14 years, 2 months ago) by efrank
Changes since 1.10: +4 -0 lines
Diff to previous 1.10 , to selected 1.7
     'by_raw_alias'   => $wrapper->wrap_array_return("by_raw_alias"),
     'find_by_attribute'   => $wrapper->wrap_array_return("find_by_attribute"),
     'get_attributes'   => $wrapper->wrap_array_return("get_attributes"),
     'get_cv_attributes'   => $wrapper->wrap_array_return("get_cv_attributes"),
Tue Jan 3 18:31:14 2006 UTC (14 years, 3 months ago) by efrank
Changes since 1.9: +4 -1 lines
Diff to previous 1.9 , to selected 1.7
change by_alias to be wrapped as array rather than scalar.
add subsystems_having_genomes( genomeId)
Mon Dec 5 19:12:12 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.8: +17 -0 lines
Diff to previous 1.8 , to selected 1.7
add license words
Thu Jul 28 00:19:48 2005 UTC (14 years, 8 months ago) by efrank
CVS Tags: caBIG-00-00-00
Changes since 1.7: +1 -0 lines
add subsystem_to_roles to the interface.
Revision 1.7 - (view) (download) (annotate) - [selected]
Sat Feb 12 03:00:08 2005 UTC (15 years, 1 month ago) by mkubal
update
Fri Feb 11 06:32:03 2005 UTC (15 years, 1 month ago) by mkubal
new methods for ModelEditor
Thu Feb 10 13:33:37 2005 UTC (15 years, 1 month ago) by olson
Add subsystems_for_genome.
Wed Feb 9 21:35:13 2005 UTC (15 years, 1 month ago) by mkubal
added subsystems_for_peg
Wed Nov 10 23:29:16 2004 UTC (15 years, 4 months ago) by olson
Kernel access support for constructs.
Mon Jun 28 20:13:18 2004 UTC (15 years, 9 months ago) by olson
Add subsystem calls
Mon May 10 21:50:36 2004 UTC (15 years, 10 months ago) by mkubal
Diff to selected 1.7
MK 5/10/04
