[Bio] / FigWebServices / index.cgi Repository:
Log of /FigWebServices/index.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Revision 1.142 - (view) (download) (annotate) - [select for diffs]
Sun Aug 28 02:35:05 2011 UTC (8 years, 7 months ago) by olson
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Changes since 1.141: +1 -1 lines
Diff to previous 1.141 , to selected 1.104
fix dumb bug
Revision 1.141 - (view) (download) (annotate) - [select for diffs]
Sun Aug 14 23:03:04 2011 UTC (8 years, 7 months ago) by golsen
Changes since 1.140: +150 -48 lines
Diff to previous 1.140 , to selected 1.104
Add identical sequence search function to "Searching DNA or Protein Sequences".
Revision 1.140 - (view) (download) (annotate) - [select for diffs]
Wed Jun 22 21:11:37 2011 UTC (8 years, 9 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1, myrast_rel40
Changes since 1.139: +7 -13 lines
Diff to previous 1.139 , to selected 1.104
Update to use the new Sphinx support in SeedSearch and sphinx_index_genome
Revision 1.139 - (view) (download) (annotate) - [select for diffs]
Thu Jan 27 22:36:58 2011 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33
Changes since 1.138: +6 -4 lines
Diff to previous 1.138 , to selected 1.104
different flavor of sphinx fix
Revision 1.138 - (view) (download) (annotate) - [select for diffs]
Sun Jan 2 19:19:26 2011 UTC (9 years, 2 months ago) by golsen
CVS Tags: rast_rel_2011_0119
Changes since 1.137: +2 -0 lines
Diff to previous 1.137 , to selected 1.104
Disable use strict 'subs' for one line of Sphinx code that looks like a
bareword if Sphix::Search did not load.
Revision 1.137 - (view) (download) (annotate) - [select for diffs]
Thu Dec 23 18:03:19 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.136: +403 -340 lines
Diff to previous 1.136 , to selected 1.104
Caching / FCGI speedup modifications.
Revision 1.136 - (view) (download) (annotate) - [select for diffs]
Mon Jun 7 20:54:49 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.135: +15 -10 lines
Diff to previous 1.135 , to selected 1.104
sphinx fixes
Revision 1.135 - (view) (download) (annotate) - [select for diffs]
Thu Apr 15 17:13:28 2010 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.134: +34 -6 lines
Diff to previous 1.134 , to selected 1.104
Add paging in sphinx search
Revision 1.134 - (view) (download) (annotate) - [select for diffs]
Thu Apr 15 16:40:22 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.133: +56 -1 lines
Diff to previous 1.133 , to selected 1.104
Add sphinx search support.
Revision 1.133 - (view) (download) (annotate) - [select for diffs]
Wed Aug 26 00:05:15 2009 UTC (10 years, 7 months ago) by golsen
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118
Changes since 1.132: +8 -2 lines
Diff to previous 1.132 , to selected 1.104
Make the "use new subsytem editor" message go away when it is useless.
Revision 1.132 - (view) (download) (annotate) - [select for diffs]
Fri Sep 26 14:48:24 2008 UTC (11 years, 6 months ago) by overbeek
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09
Changes since 1.131: +8 -2 lines
Diff to previous 1.131 , to selected 1.104
set links to seed_viewer for anno3
Revision 1.131 - (view) (download) (annotate) - [select for diffs]
Thu Sep 4 13:07:26 2008 UTC (11 years, 6 months ago) by paczian
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.130: +18 -13 lines
Diff to previous 1.130 , to selected 1.104
included redirect rule for anno3_mode to point fig-id searches to seedviewer.cgi instead of protein.cgi
Revision 1.130 - (view) (download) (annotate) - [select for diffs]
Tue Apr 29 08:09:05 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.129: +0 -1 lines
Diff to previous 1.129 , to selected 1.104
Added Etracing support.
Revision 1.129 - (view) (download) (annotate) - [select for diffs]
Wed Mar 19 12:47:40 2008 UTC (12 years ago) by overbeek
CVS Tags: rast_rel_2008_04_23
Changes since 1.128: +2 -1 lines
Diff to previous 1.128 , to selected 1.104
fixes to support comparing genomes under RAST
Revision 1.128 - (view) (download) (annotate) - [select for diffs]
Fri Mar 7 11:22:29 2008 UTC (12 years ago) by overbeek
Changes since 1.127: +10 -0 lines
Diff to previous 1.127 , to selected 1.104
add links to clust_ss.cgi to index.cgi
Revision 1.127 - (view) (download) (annotate) - [select for diffs]
Fri Nov 30 22:50:40 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.126: +2 -0 lines
Diff to previous 1.126 , to selected 1.104
add a link to daniela's new editor
Revision 1.126 - (view) (download) (annotate) - [select for diffs]
Tue Oct 30 19:14:11 2007 UTC (12 years, 5 months ago) by golsen
Changes since 1.125: +43 -2 lines
Diff to previous 1.125 , to selected 1.104
Add filtering of deleted fids to the display of blast similarities.
Revision 1.125 - (view) (download) (annotate) - [select for diffs]
Fri Oct 12 15:20:58 2007 UTC (12 years, 5 months ago) by overbeek
Changes since 1.124: +20 -3 lines
Diff to previous 1.124 , to selected 1.104
handle comments in function translation
Revision 1.124 - (view) (download) (annotate) - [select for diffs]
Fri Aug 10 03:16:31 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.123: +5 -5 lines
Diff to previous 1.123 , to selected 1.104
more fixes resulting from change to korgs organism list.
Revision 1.123 - (view) (download) (annotate) - [select for diffs]
Wed Aug 8 20:45:55 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.122: +34 -16 lines
Diff to previous 1.122 , to selected 1.104
Fix per-org search problem by using separated values and value->label map in the CGI scrolling list
of organism names. This shoudl get propagated to the other scrolling lists of orgs.
Revision 1.122 - (view) (download) (annotate) - [select for diffs]
Wed Jun 20 20:48:11 2007 UTC (12 years, 9 months ago) by olson
Changes since 1.121: +2 -0 lines
Diff to previous 1.121 , to selected 1.104
fix protein page redirects for CGI.pm in perl 5.8.8.
Revision 1.121 - (view) (download) (annotate) - [select for diffs]
Tue Jun 12 21:32:30 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.120: +0 -8 lines
Diff to previous 1.120 , to selected 1.104
fix error in index.cgi
Revision 1.120 - (view) (download) (annotate) - [select for diffs]
Sat Jun 9 12:23:32 2007 UTC (12 years, 9 months ago) by overbeek
Changes since 1.119: +53 -0 lines
Diff to previous 1.119 , to selected 1.104
add ability to filter aux roles on peg_to_subsystems
Revision 1.119 - (view) (download) (annotate) - [select for diffs]
Mon Apr 9 15:12:11 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.118: +2 -1 lines
Diff to previous 1.118 , to selected 1.104
fixes to Gary's comparison of genomes
Revision 1.118 - (view) (download) (annotate) - [select for diffs]
Sun Apr 8 23:21:03 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.117: +1 -1 lines
Diff to previous 1.117 , to selected 1.104
enhancements to Gary's genome comparison tool
Revision 1.117 - (view) (download) (annotate) - [select for diffs]
Sun Apr 8 21:36:16 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.116: +22 -0 lines
Diff to previous 1.116 , to selected 1.104
add Gary's compare genome stuff
Revision 1.116 - (view) (download) (annotate) - [select for diffs]
Mon Mar 12 01:13:24 2007 UTC (13 years ago) by overbeek
Changes since 1.115: +19 -0 lines
Diff to previous 1.115 , to selected 1.104
basic ability to compare metabolic reconstructions
Revision 1.115 - (view) (download) (annotate) - [select for diffs]
Mon Jan 22 20:11:25 2007 UTC (13 years, 2 months ago) by parrello
Changes since 1.114: +10 -43 lines
Diff to previous 1.114 , to selected 1.104
Adapted to new search display format for attribute-related searches.
Added tracing.
Revision 1.114 - (view) (download) (annotate) - [select for diffs]
Wed Jan 3 15:46:25 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.113: +6 -0 lines
Diff to previous 1.113 , to selected 1.104
add ability to work on FIGfams
Revision 1.113 - (view) (download) (annotate) - [select for diffs]
Thu Dec 28 03:30:32 2006 UTC (13 years, 3 months ago) by golsen
Changes since 1.112: +48 -31 lines
Diff to previous 1.112 , to selected 1.104
Add support for plasmids to the genome picker.
Revision 1.112 - (view) (download) (annotate) - [select for diffs]
Fri Oct 27 00:47:48 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.111: +12 -0 lines
Diff to previous 1.111 , to selected 1.104
add find_ss_genes.cgi
Revision 1.111 - (view) (download) (annotate) - [select for diffs]
Wed Jul 19 21:59:16 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.110: +1 -1 lines
Diff to previous 1.110 , to selected 1.104
RAE: Getting rid of this is the new code
Revision 1.110 - (view) (download) (annotate) - [select for diffs]
Fri Jun 30 15:20:43 2006 UTC (13 years, 9 months ago) by mkubal
Changes since 1.109: +0 -32 lines
Diff to previous 1.109 , to selected 1.104
download_search_clearresults
Revision 1.109 - (view) (download) (annotate) - [select for diffs]
Fri Jun 30 15:10:18 2006 UTC (13 years, 9 months ago) by mkubal
Changes since 1.108: +49 -3 lines
Diff to previous 1.108 , to selected 1.104
Revision 1.108 - (view) (download) (annotate) - [select for diffs]
Tue Jun 6 17:34:37 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.107: +1 -1 lines
Diff to previous 1.107 , to selected 1.104
RAE: correcting the lack of sort on genomes list in index.cgi. Sorry!
Revision 1.107 - (view) (download) (annotate) - [select for diffs]
Tue Jun 6 02:25:37 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.106: +17 -2 lines
Diff to previous 1.106 , to selected 1.104
RAE: adding more to heatmap, and removing the contigs for environmental samples
Revision 1.106 - (view) (download) (annotate) - [select for diffs]
Sat May 20 01:33:49 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.105: +1 -1 lines
Diff to previous 1.105 , to selected 1.104
RAE: Sorting index.cgi search results by genus/species
Revision 1.105 - (view) (download) (annotate) - [select for diffs]
Fri May 5 17:52:36 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.104: +4 -1 lines
Diff to previous 1.104
hook in display of log entries
Revision 1.104 - (view) (download) (annotate) - [selected]
Thu Mar 2 20:56:15 2006 UTC (14 years, 1 month ago) by golsen
Changes since 1.103: +1 -1 lines
Diff to previous 1.103
Disable "propose_new_peg.cgi" link for blastn.
Revision 1.103 - (view) (download) (annotate) - [select for diffs]
Thu Mar 2 20:53:06 2006 UTC (14 years, 1 month ago) by golsen
Changes since 1.102: +48 -27 lines
Diff to previous 1.102 , to selected 1.104
Fixed calculation of region displayed in blastn and tblastn so that query
location is included.
Minor clean-up of "blast all complete genomes" in preparation for alignment
and tree options (not just extract sequences).
Revision 1.102 - (view) (download) (annotate) - [select for diffs]
Wed Feb 22 19:54:17 2006 UTC (14 years, 1 month ago) by paczian
Changes since 1.101: +12 -5 lines
Diff to previous 1.101 , to selected 1.104
Revision 1.101 - (view) (download) (annotate) - [select for diffs]
Sun Feb 5 01:08:16 2006 UTC (14 years, 1 month ago) by overbeek
Changes since 1.100: +1 -1 lines
Diff to previous 1.100 , to selected 1.104
RAE: Swtiched to using SQL Count for the number of contigs
Revision 1.100 - (view) (download) (annotate) - [select for diffs]
Thu Jan 19 18:23:55 2006 UTC (14 years, 2 months ago) by golsen
Changes since 1.99: +4 -2 lines
Diff to previous 1.99 , to selected 1.104
Move "UniProt WebService Search" slightly to aviod increasing the page
width.
Revision 1.99 - (view) (download) (annotate) - [select for diffs]
Tue Jan 17 18:59:58 2006 UTC (14 years, 2 months ago) by mkubal
Changes since 1.98: +2 -1 lines
Diff to previous 1.98 , to selected 1.104
link to UniProt WebService
Revision 1.98 - (view) (download) (annotate) - [select for diffs]
Sun Jan 15 01:43:06 2006 UTC (14 years, 2 months ago) by golsen
Changes since 1.97: +8 -7 lines
Diff to previous 1.97 , to selected 1.104
Don't let e-value wrap in blastp of all complete genomes output table.
Revision 1.97 - (view) (download) (annotate) - [select for diffs]
Wed Jan 4 19:32:00 2006 UTC (14 years, 2 months ago) by golsen
Changes since 1.96: +98 -69 lines
Diff to previous 1.96 , to selected 1.104
Add a page for proposing a new PEG.  This is not complete, and the 'create'
button is currently functionless, but it is worth some feedback as to the
direction it is headed.
The page is linked from the graphical display of tblastn output in index.cgi
(click on the "Q" object in the figure) (intentionally obscure for now).
Add a new blast output parsing perl package.  This can read from a file,
a pipe or a text array of lines (D=STDIN).  It can collect all output
(possibly memory intensive), or it can deliver quanta of output by being
called repeatedly with the same HANDLE or ARRAY (which can be made very
memory light).  It maintains separate state information for each input,
so multiple open streams works (silly me).  [Note that this is for full
text output, not the tabular output.  The alignments are also returned.
If you don't want them, slice-up the output with map{}.  You also get
useful information such as query and subject definitions (not just ids),
and their lengths.  There are huge quantities of description in the file.
It should work with all recent versions of blastall, and all -p options,
with the possible exception of tblastx, but it might work on that too.]
This package is intended to replace, and extend, all of the functionality
previously achieved by piping output through the rationalize_blast script.
Because it no longer requires the script, the shell invocation is no
longer required.  And this works with pipes opened with '-|', so ....
It is currently used in index.cgi and propose_new_peg.cgi.
Revision 1.96 - (view) (download) (annotate) - [select for diffs]
Thu Dec 29 21:28:53 2005 UTC (14 years, 3 months ago) by golsen
Changes since 1.95: +21 -13 lines
Diff to previous 1.95 , to selected 1.104
Add genome to description lines with "Extract Matched Sequences".
Revision 1.95 - (view) (download) (annotate) - [select for diffs]
Wed Dec 28 21:22:48 2005 UTC (14 years, 3 months ago) by golsen
Changes since 1.94: +31 -27 lines
Diff to previous 1.94 , to selected 1.104
Slight clean-up of text search interface.
Revision 1.94 - (view) (download) (annotate) - [select for diffs]
Wed Dec 7 21:07:24 2005 UTC (14 years, 3 months ago) by golsen
Changes since 1.93: +1 -1 lines
Diff to previous 1.93 , to selected 1.104
Very minor text change on blastn and tblastn display.  Slight clarification.
Revision 1.93 - (view) (download) (annotate) - [select for diffs]
Mon Dec 5 19:12:12 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.92: +17 -0 lines
Diff to previous 1.92 , to selected 1.104
add license words
Revision 1.92 - (view) (download) (annotate) - [select for diffs]
Fri Nov 18 22:46:32 2005 UTC (14 years, 4 months ago) by efrank
Changes since 1.91: +140 -0 lines
Diff to previous 1.91 , to selected 1.104
extend search capability.  added dropdown that lets you select "Directly"
"Via GO" or "Via Hugo."   "Directly" corresponds to the search we've always
done.  The "Via X" causes the search to search for terms in vocabulary
X and return those terms via a substring search.  The returned, (full) terms
can then be used to launch a normal PEG search.  so, if you know say "kinase"
but not the full GO term, you can use this to find it then find the pegs
having that.
tested and proved it does not blow up if the cv files are not installed.
Revision 1.91 - (view) (download) (annotate) - [select for diffs]
Tue Nov 15 01:45:25 2005 UTC (14 years, 4 months ago) by golsen
Changes since 1.90: +36 -19 lines
Diff to previous 1.90 , to selected 1.104
Fixed bug in fid-based query sequence for "blastp against complete
genomes".  A protein query is now supplied.  Made numerous small
changes in the behaviour.
One score per database sequence.
Sort by bit-score.
Turn on low-complexity filtering.
Limit output to 1000 sequences.
Put blank spaces into alias list so that it can wrap.
Use the "execute_blast" routine to exec blast as a child without shell.
Some general code clean-up.
Revision 1.90 - (view) (download) (annotate) - [select for diffs]
Thu Nov 3 22:07:59 2005 UTC (14 years, 4 months ago) by olson
CVS Tags: caBIG-00-00-00
Changes since 1.89: +1 -1 lines
Diff to previous 1.89 , to selected 1.104
fixes.
Revision 1.89 - (view) (download) (annotate) - [select for diffs]
Thu Nov 3 22:04:53 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.88: +12 -41 lines
Diff to previous 1.88 , to selected 1.104
New index.cgi using FIG_CGI
Revision 1.88 - (view) (download) (annotate) - [select for diffs]
Mon Oct 24 21:42:53 2005 UTC (14 years, 5 months ago) by golsen
Changes since 1.87: +36 -15 lines
Diff to previous 1.87 , to selected 1.104
Use exec to prevent shell interpretation of blast options (security
hole).
Revision 1.87 - (view) (download) (annotate) - [select for diffs]
Mon Oct 24 14:41:30 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.86: +2 -4 lines
Diff to previous 1.86 , to selected 1.104
removing cookies
Revision 1.86 - (view) (download) (annotate) - [select for diffs]
Sun Oct 23 23:11:53 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.85: +22 -0 lines
Diff to previous 1.85 , to selected 1.104
put back in Gary Olsens code to graphically display a tblastn hit
Revision 1.85 - (view) (download) (annotate) - [select for diffs]
Tue Oct 18 20:11:45 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.84: +4 -4 lines
Diff to previous 1.84 , to selected 1.104
remove debug.
Revision 1.84 - (view) (download) (annotate) - [select for diffs]
Thu Oct 13 21:52:56 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.83: +1 -1 lines
Diff to previous 1.83 , to selected 1.104
add an anchor to the "exporting assignments" section.
Revision 1.83 - (view) (download) (annotate) - [select for diffs]
Thu Oct 13 20:14:26 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.82: +27 -0 lines
Diff to previous 1.82 , to selected 1.104
Display the file FIGdisk/config/motd, if it exists, on the SEED front apge.
Revision 1.82 - (view) (download) (annotate) - [select for diffs]
Wed Oct 12 21:03:16 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.81: +1 -1 lines
Diff to previous 1.81 , to selected 1.104
Revision 1.81 - (view) (download) (annotate) - [select for diffs]
Sat Oct 8 14:14:47 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.80: +6 -0 lines
Diff to previous 1.80 , to selected 1.104
minor fix to not include xxx entries in expanded sims
Revision 1.80 - (view) (download) (annotate) - [select for diffs]
Mon Oct 3 20:05:34 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.79: +5 -2 lines
Diff to previous 1.79 , to selected 1.104
Initial release of cookies code, including myseed
Revision 1.79 - (view) (download) (annotate) - [select for diffs]
Fri Sep 16 04:24:43 2005 UTC (14 years, 6 months ago) by mkubal
Changes since 1.78: +3 -3 lines
Diff to previous 1.78 , to selected 1.104
search can now find find phage and pi
Revision 1.78 - (view) (download) (annotate) - [select for diffs]
Tue Aug 16 20:30:26 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.77: +15 -3 lines
Diff to previous 1.77 , to selected 1.104
Added some trace messages. Fixed a compatability problem with the use of the back-tick operator.
Revision 1.77 - (view) (download) (annotate) - [select for diffs]
Wed Aug 10 17:13:45 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.76: +3 -1 lines
Diff to previous 1.76 , to selected 1.104
fixes to displaying reactions and status of models
Revision 1.76 - (view) (download) (annotate) - [select for diffs]
Thu Aug 4 22:25:12 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.75: +1 -1 lines
Diff to previous 1.75 , to selected 1.104
fixing help links
Revision 1.75 - (view) (download) (annotate) - [select for diffs]
Tue Jul 26 20:22:47 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.74: +531 -553 lines
Diff to previous 1.74 , to selected 1.104
Fixed indenting.
Revision 1.74 - (view) (download) (annotate) - [select for diffs]
Tue Jul 26 17:37:47 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.73: +4 -1 lines
Diff to previous 1.73 , to selected 1.104
handle bad maps
Revision 1.73 - (view) (download) (annotate) - [select for diffs]
Fri Jul 15 04:48:56 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.72: +10 -6 lines
Diff to previous 1.72 , to selected 1.104
fix translate functions
Revision 1.72 - (view) (download) (annotate) - [select for diffs]
Sun Jul 10 18:17:42 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.71: +1 -0 lines
Diff to previous 1.71 , to selected 1.104
Add project description to genome statistics report.
Format PEG statistics as a table (easier to read).
Add title to "Statistics Page" when no genome is selected.
Some minor code clean up.
Revision 1.71 - (view) (download) (annotate) - [select for diffs]
Sun Jun 19 02:28:31 2005 UTC (14 years, 9 months ago) by overbeek
CVS Tags: merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2
Changes since 1.70: +1 -1 lines
Diff to previous 1.70 , to selected 1.104
escape | in some search patterns
Revision 1.70 - (view) (download) (annotate) - [select for diffs]
Tue May 17 16:04:08 2005 UTC (14 years, 10 months ago) by olson
CVS Tags: Root-bobdev_news
Changes since 1.69: +2 -1 lines
Diff to previous 1.69 , to selected 1.104
Revision 1.69 - (view) (download) (annotate) - [select for diffs]
Fri Apr 15 18:13:18 2005 UTC (14 years, 11 months ago) by golsen
Changes since 1.68: +8 -7 lines
Diff to previous 1.68 , to selected 1.104
New subsystems code is now the official code.
Revision 1.68 - (view) (download) (annotate) - [select for diffs]
Thu Apr 7 04:54:02 2005 UTC (14 years, 11 months ago) by golsen
Changes since 1.67: +4 -2 lines
Diff to previous 1.67 , to selected 1.104
Add a "view simiarities" option to the text search report page.  Provide
the user with a form to define similarities options, and with links to
the protein similarities page for each of the selected proteins.
Revision 1.67 - (view) (download) (annotate) - [select for diffs]
Thu Apr 7 02:57:19 2005 UTC (14 years, 11 months ago) by golsen
Changes since 1.66: +6 -27 lines
Diff to previous 1.66 , to selected 1.104
Clean-up to remove superfluous code, variables and parameters from the
text search report code, now that RAE has done it with JavaScript (much
nicer that way).
Revision 1.66 - (view) (download) (annotate) - [select for diffs]
Wed Apr 6 22:40:40 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.65: +1 -0 lines
Diff to previous 1.65 , to selected 1.104
adding help functions all over the place
Revision 1.65 - (view) (download) (annotate) - [select for diffs]
Sun Mar 27 22:20:39 2005 UTC (15 years ago) by golsen
Changes since 1.64: +249 -1 lines
Diff to previous 1.64 , to selected 1.104
Add graphics to blastn and tblastn hits on contigs.  Hot link the proteins
to the protein pages.  Color-code proteins by their translation frame, so
the relative frames of tblastn matches and existing protein features is
easily seen.
Revision 1.64 - (view) (download) (annotate) - [select for diffs]
Wed Mar 16 17:52:34 2005 UTC (15 years ago) by golsen
Changes since 1.63: +9 -9 lines
Diff to previous 1.63 , to selected 1.104
Cosmetic interface changes on entry page
Revision 1.63 - (view) (download) (annotate) - [select for diffs]
Sun Mar 13 21:32:38 2005 UTC (15 years ago) by redwards
Changes since 1.62: +36 -11 lines
Diff to previous 1.62 , to selected 1.104
Allow searching groups of organisms and add search to organisms.cgi
Revision 1.62 - (view) (download) (annotate) - [select for diffs]
Wed Mar 9 18:08:44 2005 UTC (15 years ago) by golsen
Changes since 1.61: +6 -2 lines
Diff to previous 1.61 , to selected 1.104
Enable hot links from proteins and external protein identifiers on Assignment export page
Revision 1.61 - (view) (download) (annotate) - [select for diffs]
Sun Mar 6 15:10:02 2005 UTC (15 years ago) by overbeek
Changes since 1.60: +2 -2 lines
Diff to previous 1.60 , to selected 1.104
disconnect get_attributes until I can talk to Rob
Revision 1.60 - (view) (download) (annotate) - [select for diffs]
Tue Feb 15 05:17:31 2005 UTC (15 years, 1 month ago) by golsen
Changes since 1.59: +8 -10 lines
Diff to previous 1.59 , to selected 1.104
Add some more formating nicities.
Revision 1.59 - (view) (download) (annotate) - [select for diffs]
Tue Feb 15 05:01:23 2005 UTC (15 years, 1 month ago) by golsen
Changes since 1.58: +54 -26 lines
Diff to previous 1.58 , to selected 1.104
Make organism-specific text search an option, not default.  Remove filtering of roles (which I think was incorrect).  Add some formating nicities.
Revision 1.58 - (view) (download) (annotate) - [select for diffs]
Fri Jan 28 18:16:57 2005 UTC (15 years, 2 months ago) by redwards
Changes since 1.57: +1 -1 lines
Diff to previous 1.57 , to selected 1.104
Added a reset button to index.cgi so you can escape from a bug where you have selected an organism
and then can't deselect that.
Revision 1.57 - (view) (download) (annotate) - [select for diffs]
Wed Jan 26 23:46:20 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.56: +10 -0 lines
Diff to previous 1.56 , to selected 1.104
fix bug in removing genomes from a subsystem
Revision 1.56 - (view) (download) (annotate) - [select for diffs]
Wed Jan 26 19:58:00 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.55: +16 -7 lines
Diff to previous 1.55 , to selected 1.104
allow multiple translations
Revision 1.55 - (view) (download) (annotate) - [select for diffs]
Sun Jan 23 15:43:49 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.54: +12 -8 lines
Diff to previous 1.54 , to selected 1.104
fixes to index.cgi
Revision 1.54 - (view) (download) (annotate) - [select for diffs]
Wed Dec 8 16:56:24 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.53: +24 -1 lines
Diff to previous 1.53 , to selected 1.104
add informative errors about the server not being running.
Revision 1.53 - (view) (download) (annotate) - [select for diffs]
Wed Nov 24 18:27:06 2004 UTC (15 years, 4 months ago) by redwards
Changes since 1.52: +25 -0 lines
Diff to previous 1.52 , to selected 1.104
Modified index.cgi so that if an organism is selected the text search will only return results from
that organism, as per Matt's request. If no organism is selected this will still return all the results
Revision 1.52 - (view) (download) (annotate) - [select for diffs]
Thu Nov 4 18:27:29 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.51: +11 -3 lines
Diff to previous 1.51 , to selected 1.104
allow external IDs on subsystem displays
Revision 1.51 - (view) (download) (annotate) - [select for diffs]
Thu Nov 4 16:13:35 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.50: +65 -1 lines
Diff to previous 1.50 , to selected 1.104
add ability to find subsystems for OlgaZ
Revision 1.50 - (view) (download) (annotate) - [select for diffs]
Sun Oct 24 02:45:41 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.49: +16 -4 lines
Diff to previous 1.49 , to selected 1.104
minor additions to genome statistics
Revision 1.49 - (view) (download) (annotate) - [select for diffs]
Sat Oct 23 19:51:41 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.48: +27 -3 lines
Diff to previous 1.48 , to selected 1.104
introduce genome statistics
Revision 1.48 - (view) (download) (annotate) - [select for diffs]
Fri Oct 8 22:04:48 2004 UTC (15 years, 5 months ago) by redwards
Changes since 1.47: +2 -2 lines
Diff to previous 1.47 , to selected 1.104
Added number of contigs to menu
Revision 1.47 - (view) (download) (annotate) - [select for diffs]
Sat Sep 11 00:45:40 2004 UTC (15 years, 6 months ago) by golsen
Changes since 1.46: +80 -20 lines
Diff to previous 1.46 , to selected 1.104
Add domain and completeness controls to organism selection list.
Revision 1.46 - (view) (download) (annotate) - [select for diffs]
Tue Sep 7 02:54:16 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.45: +8 -6 lines
Diff to previous 1.45 , to selected 1.104
add new subsystem interface
Revision 1.45 - (view) (download) (annotate) - [select for diffs]
Fri Aug 20 22:19:55 2004 UTC (15 years, 7 months ago) by golsen
Changes since 1.44: +41 -28 lines
Diff to previous 1.44 , to selected 1.104
Clean-up of blast interface in preparation for adding functionality to tblastn output
Revision 1.44 - (view) (download) (annotate) - [select for diffs]
Tue Jul 27 21:41:05 2004 UTC (15 years, 8 months ago) by golsen
Changes since 1.43: +1 -1 lines
Diff to previous 1.43 , to selected 1.104
testing that my cvs works now
Revision 1.43 - (view) (download) (annotate) - [select for diffs]
Wed Jun 30 17:59:52 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.42: +1 -1 lines
Diff to previous 1.42 , to selected 1.104
change label on map section
Revision 1.42 - (view) (download) (annotate) - [select for diffs]
Mon Jun 28 20:22:42 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.41: +16 -16 lines
Diff to previous 1.41 , to selected 1.104
Move the subsystem block out of the middle of the other form
Revision 1.41 - (view) (download) (annotate) - [select for diffs]
Mon Jun 28 19:36:33 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.40: +42 -37 lines
Diff to previous 1.40 , to selected 1.104
more cleanup
Revision 1.40 - (view) (download) (annotate) - [select for diffs]
Mon Jun 28 19:14:22 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.39: +0 -19 lines
Diff to previous 1.39 , to selected 1.104
New page header
Revision 1.39 - (view) (download) (annotate) - [select for diffs]
Wed Jun 23 15:41:33 2004 UTC (15 years, 9 months ago) by disz
Changes since 1.38: +7 -7 lines
Diff to previous 1.38 , to selected 1.104
local map fixes, removed extra subsystem logon lines
Revision 1.38 - (view) (download) (annotate) - [select for diffs]
Wed Jun 16 14:25:36 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.37: +11 -2 lines
Diff to previous 1.37 , to selected 1.104
New map support.
Revision 1.37 - (view) (download) (annotate) - [select for diffs]
Wed Jun 16 14:06:17 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.36: +4 -1 lines
Diff to previous 1.36 , to selected 1.104
add link to control panel
Revision 1.36 - (view) (download) (annotate) - [select for diffs]
Mon Jun 14 22:09:40 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.35: +11 -3 lines
Diff to previous 1.35 , to selected 1.104
add cvs release date to header
Revision 1.35 - (view) (download) (annotate) - [select for diffs]
Thu Jun 3 00:17:29 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.34: +2 -3 lines
Diff to previous 1.34 , to selected 1.104
fix invocation of protein.cgi from index.cgi
Revision 1.34 - (view) (download) (annotate) - [select for diffs]
Tue May 11 16:17:06 2004 UTC (15 years, 10 months ago) by olson
Changes since 1.33: +1 -2 lines
Diff to previous 1.33 , to selected 1.104
Remove the old p2p link.
Revision 1.33 - (view) (download) (annotate) - [select for diffs]
Sat May 8 07:56:45 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.32: +3 -1 lines
Diff to previous 1.32 , to selected 1.104
minor fixes
Revision 1.32 - (view) (download) (annotate) - [select for diffs]
Wed May 5 16:40:35 2004 UTC (15 years, 10 months ago) by disz
Changes since 1.31: +1 -2 lines
Diff to previous 1.31 , to selected 1.104
Single p2 link again
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Mon May 3 17:04:11 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.30: +34 -0 lines
Diff to previous 1.30 , to selected 1.104
fixes to links in HTML.pm, code to sync systems after an update, and fixes to index.cgi and protein.cgi
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Fri Apr 23 21:49:03 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.29: +117 -6 lines
Diff to previous 1.29 , to selected 1.104
fixes to index.cgi to blast against all complete
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Sun Apr 11 20:22:18 2004 UTC (15 years, 11 months ago) by golsen
Changes since 1.28: +10 -3 lines
Diff to previous 1.28 , to selected 1.104
Minor format changes in Searching DNA or Protein Sequences; primarily a test that my code is upto date
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Thu Apr 8 16:38:05 2004 UTC (15 years, 11 months ago) by overbeek
Changes since 1.27: +51 -4 lines
Diff to previous 1.27 , to selected 1.104
support translation generation of new assignments
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Fri Apr 2 18:02:20 2004 UTC (16 years ago) by overbeek
Changes since 1.26: +7 -1 lines
Diff to previous 1.26 , to selected 1.104
add a new version of the spreadsheet software
Thu Apr 1 18:36:23 2004 UTC (16 years ago) by disz
Changes since 1.25: +4 -2 lines
Diff to previous 1.25 , to selected 1.104
Added subsystems to p2p
Fri Mar 26 21:54:11 2004 UTC (16 years ago) by olson
Changes since 1.24: +1 -1 lines
Diff to previous 1.24 , to selected 1.104
Fix baseurl stuff some more.
Fri Mar 26 21:42:55 2004 UTC (16 years ago) by olson
Changes since 1.23: +2 -1 lines
Diff to previous 1.23 , to selected 1.104
add hostname to the banner
Sun Mar 21 02:20:55 2004 UTC (16 years ago) by golsen
Changes since 1.22: +18 -8 lines
Diff to previous 1.22 , to selected 1.104
Add HTML structuring tags in HTML.pm; Add titles to some pages in index.cgi and protein.cgi; Pretty-up the HTML produced for tables (add newlines and indents)
Fri Mar 19 22:48:15 2004 UTC (16 years ago) by golsen
Changes since 1.21: +4 -4 lines
Diff to previous 1.21 , to selected 1.104
More cleanly localize checkbox control for show_indexed_objects.
Fri Mar 19 21:58:31 2004 UTC (16 years ago) by golsen
Changes since 1.20: +13 -13 lines
Diff to previous 1.20 , to selected 1.104
Relative base address support and cgi_url() based on current http request
Fri Mar 5 19:18:37 2004 UTC (16 years ago) by olson
Diff to previous 1.19 , to selected 1.104
CHange reference to p2p update script
Mon Feb 23 17:28:24 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.18: +11 -0 lines
Diff to previous 1.18 , to selected 1.104
fixes to ssa.cgi
Thu Feb 19 14:37:02 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.17: +2 -1 lines
Diff to previous 1.17 , to selected 1.104
fix urls to get them plugged correctly
Sun Feb 15 17:12:54 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.16: +165 -54 lines
Diff to previous 1.16 , to selected 1.104
added Gary Olsen changes
Fri Feb 13 20:29:28 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.15: +1 -0 lines
Diff to previous 1.15 , to selected 1.104
clip master: when saving assignments
Tue Feb 10 18:44:58 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.14: +5 -2 lines
Diff to previous 1.14 , to selected 1.104
try to fix importing assignments (the user)
Fri Jan 16 14:59:48 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.13: +9 -1 lines
Diff to previous 1.13 , to selected 1.104
add ability to process assignment sets
Wed Jan 14 20:20:32 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.12: +17 -6 lines
Diff to previous 1.12 , to selected 1.104
synch up Ross
Wed Jan 7 03:34:13 2004 UTC (16 years, 2 months ago) by overbeek
Diff to previous 1.11 , to selected 1.104
make Assignments files have readable names
Wed Jan 7 03:12:44 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.10: +15 -1 lines
Diff to previous 1.10 , to selected 1.104
make p2p assignments get written to Assignments
Tue Jan 6 18:14:48 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.9: +4 -1 lines
Diff to previous 1.9 , to selected 1.104
fix stick behavior for checked sims
Sat Jan 3 14:13:48 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.8: +1 -38 lines
Diff to previous 1.8 , to selected 1.104
fix P2P to use get_assignments
Sat Jan 3 13:47:50 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.7: +10 -2 lines
Diff to previous 1.7 , to selected 1.104
added ma field to annotations to indicate master assignments
Sat Jan 3 06:03:43 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.6: +104 -1 lines
Diff to previous 1.6 , to selected 1.104
changes to annotations to allow extraction of assignments
Sun Dec 28 17:11:29 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.5: +4 -3 lines
Diff to previous 1.5 , to selected 1.104
cleanup issues relating to large numbers of partial genomes
Tue Dec 23 16:53:37 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.4: +7 -1 lines
Diff to previous 1.4 , to selected 1.104
P2P Stuff
Wed Dec 17 16:27:11 2003 UTC (16 years, 3 months ago) by efrank
Diff to previous 1.3 , to selected 1.104
:P2P Stuff
Tue Dec 16 16:59:42 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.2: +0 -13 lines
Diff to previous 1.2 , to selected 1.104
Removed stray tool_hdr content that got copied in here
Wed Dec 3 21:24:31 2003 UTC (16 years, 3 months ago) by overbeek
CVS Tags: delong-01, delong-02
Changes since 1.1: +18 -1 lines
Diff to previous 1.1 , to selected 1.104
Mon Dec 1 16:57:09 2003 UTC (16 years, 4 months ago) by efrank
Branch point for: initial
Diff to selected 1.104
