[Bio] / FigWebServices / homologs_in_clusters.cgi Repository:
Log of /FigWebServices/homologs_in_clusters.cgi
Revision 1.14 - (view) (download) (annotate) - [selected]
Wed Oct 15 11:49:20 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.13: +5 -0 lines
Redirected to evidence page if called from NMPDR.
Tue Apr 29 08:08:25 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.12: +6 -14 lines
Diff to previous 1.12 , to selected 1.14
Changed to use FIG_CGI.
Fri May 11 06:17:14 2007 UTC (12 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.11: +4 -3 lines
Diff to previous 1.11 , to selected 1.14
Fixed to use an NMPDR template.
Fri Jul 28 02:07:28 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.10 , to selected 1.14
Changed to use the new PageBuilder call signature.
Sun Jun 25 03:27:17 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.9: +6 -6 lines
Diff to previous 1.9 , to selected 1.14
Changed boundaries_of from a static to an instance method.
Mon Dec 5 19:12:12 2005 UTC (14 years ago) by olson
Changes since 1.8: +17 -0 lines
Diff to previous 1.8 , to selected 1.14
add license words
Revision 1.3.2.3 - (view) (download) (annotate) - [select for diffs]
Tue Jul 12 15:39:01 2005 UTC (14 years, 5 months ago) by olson
Branch: Branch-bobdev_news
CVS Tags: merge-bodev_news-3
Changes since 1.3.2.2: +2 -2 lines
Diff to previous 1.3.2.2 , to branch point 1.3 , to next main 1.14
Merged changes from trunk.
Sun Jul 3 03:07:40 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-00-00-00, merge-trunktag-bodev_news-3
Diff to previous 1.7 , to selected 1.14
minor corrections to displays of functional coupling
Revision 1.3.2.2 - (view) (download) (annotate) - [select for diffs]
Wed Jun 29 16:11:00 2005 UTC (14 years, 5 months ago) by olson
CVS Tags: merge-bobdev_news-2
Changes since 1.3.2.1: +24 -4 lines
Diff to previous 1.3.2.1 , to branch point 1.3 , to selected 1.14
Merge from trunk.
Wed Jun 29 14:48:27 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: merge-trunktag-bobdev_news-2
Diff to previous 1.6 , to selected 1.14
fix bug in SFXlate.pm
Wed Jun 29 13:47:58 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.5: +8 -1 lines
Diff to previous 1.5 , to selected 1.14
give message on empty result for homologs_in_clusters.cgi
Mon Jun 27 18:26:35 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.4: +14 -1 lines
Diff to previous 1.4 , to selected 1.14
Add support for NMPDR PageBuilder
Revision 1.3.2.1 - (view) (download) (annotate) - [select for diffs]
Mon Jun 27 15:26:45 2005 UTC (14 years, 5 months ago) by olson
CVS Tags: merge-bobdev_news-1
Changes since 1.3: +39 -21 lines
Diff to previous 1.3 , to selected 1.14
Merged from trunk.
Thu Jun 23 21:24:49 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: merge-trunktag-bobdev_news-1
finally
Fri Jun 3 00:27:44 2005 UTC (14 years, 6 months ago) by overbeek
CVS Tags: Root-bobdev_news
Changes since 1.2: +8 -7 lines
Diff to previous 1.2 , to selected 1.14
start removing trash in filtering automated assignments
Wed Oct 27 01:22:01 2004 UTC (15 years, 1 month ago) by redwards
Diff to previous 1.1 , to selected 1.14
Added genome name to homologs_in_clusters.cgi
Sun Oct 17 16:40:13 2004 UTC (15 years, 2 months ago) by overbeek
Diff to selected 1.14
added homologs_in_clusters.cgi
