[Bio] / FigWebServices / heat_map.cgi Repository:
Log of /FigWebServices/heat_map.cgi
Links to rast_rel_2010_1206: (view) (download) (annotate)
Thu Jun 22 23:20:31 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.19: +1 -0 lines
Diff to previous 1.19
RAE: minor changes to heat map interface
Thu Jun 22 23:10:20 2006 UTC (13 years, 9 months ago) by overbeek
Diff to previous 1.18
Thu Jun 22 23:02:05 2006 UTC (13 years, 9 months ago) by overbeek
Diff to previous 1.17
Thu Jun 22 22:46:46 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.16: +15 -5 lines
Diff to previous 1.16
Tue Jun 20 16:22:32 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.15: +1 -2 lines
RAE: adding link to table based on ss
Tue Jun 20 16:09:03 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.14: +49 -23 lines
RAE: adding limits to table based on ss
Tue Jun 20 03:56:31 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.13: +4 -2 lines
RAE: updating tables
Tue Jun 20 03:34:43 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.12: +39 -40 lines
RAE: Updating table writing in excel to deal with merged cells
Mon Jun 19 21:19:22 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.11: +5 -28 lines
RAE: Simplifying making excel tables
Mon Jun 19 15:45:29 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.10: +5 -1 lines
RAE: ignore multiple entries
Mon Jun 19 05:52:52 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.9: +10 -1 lines
RAE: sorting on tables
Mon Jun 19 05:41:50 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.8: +4 -3 lines
RAE: bordering on tables
Mon Jun 19 03:56:38 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.7: +40 -13 lines
RAE: Adding excel to heat map
Mon Jun 19 03:23:27 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.6: +49 -1 lines
RAE: Adding sig diff to heat map
Wed Jun 7 03:44:24 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.5: +6 -9 lines
RAE: better docs and sorting
Tue Jun 6 15:28:09 2006 UTC (13 years, 9 months ago) by overbeek
RAE: fixing a maximum and spread
Tue Jun 6 06:53:54 2006 UTC (13 years, 9 months ago) by overbeek
RAE: fixing a number definition
Tue Jun 6 06:31:12 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.2: +10 -3 lines
RAE: fixing numbers with 1e-5
Tue Jun 6 02:25:37 2006 UTC (13 years, 9 months ago) by overbeek
RAE: adding more to heatmap, and removing the contigs for environmental samples
Tue Jun 6 00:58:23 2006 UTC (13 years, 9 months ago) by overbeek
RAE: Initial release of a new interface that plots a heatmap of proteins that are in subsystems. The initial release is just based on a single attribute (ss_connections), but I hope to extend it to mapping on different things. Makes pretty tables though!
