[Bio] / FigWebServices / get_dlits.cgi Repository:
Log of /FigWebServices/get_dlits.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Thu Jul 10 19:52:23 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_release_2008_09_29
Changes since 1.11: +9 -2 lines
fix db query bug
Thu Jul 10 19:35:34 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.10: +59 -30 lines
A bug fix in an SQL statement in get_dlits (I still don't fully understand
the nature, but it left a query 'SELECT DISTINCT hash_role.role ...' hung).
Add code for an index of the dlits table by pubmed id.
Wed Jul 9 15:59:57 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.9: +21 -32 lines
Minor changes including:
   Display literature curator in literature curation table
   Do not display master: on literature curator
   Do not record msster: on literature curator
   Filter for real features before picking representative peg with md5
Tue Jul 8 21:26:13 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.8: +31 -18 lines
Add update of curator on propagation of 'G' status code.
Add logging of delete and insert events (but not that due to propagation
of 'G' status codes).
Tue Jul 8 19:28:47 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.7: +124 -29 lines
Add count of number of sequences linked to each reference.  Make this count
a link to all sequences in linked to the paper.
Tue Jul 8 01:39:58 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.6: +377 -187 lines
Improving navigation in the dlits scripts, and improving behavior in
the FIG.pm support for it.
Fri Jul 4 17:40:15 2008 UTC (11 years, 9 months ago) by overbeek
sort roles alphabetically
Fri Jul 4 17:36:04 2008 UTC (11 years, 9 months ago) by overbeek
show both genus and species
Sat Jun 28 20:56:11 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.3: +14 -0 lines
add table of code meanings to get_dlits.cgi
Sat Jun 28 12:12:22 2008 UTC (11 years, 9 months ago) by overbeek
Changes since 1.2: +4 -2 lines
turn off old get_dlit.cgi
Sat Jun 28 06:51:12 2008 UTC (11 years, 9 months ago) by overbeek
remove deleted FIDs from dlit checks
Fri Jun 27 14:21:18 2008 UTC (11 years, 9 months ago) by overbeek
cgi script to process dlit streams
