[Bio] / FigWebServices / genomebrowser.cgi Repository:
Log of /FigWebServices/genomebrowser.cgi
Links to mgrast_rel_2008_0625: (view) (download) (annotate)
Wed Oct 18 21:44:58 2006 UTC (13 years, 7 months ago) by redwards
minor change to allow proper genome selection
Tue Aug 1 17:57:15 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.6: +2 -1 lines
RAE: fixing genome drawing for comparative genomes
Mon Dec 5 19:12:12 2005 UTC (14 years, 6 months ago) by olson
add license words
Fri Feb 4 06:59:46 2005 UTC (15 years, 4 months ago) by redwards
Changes since 1.4: +20 -3 lines
more changes to genomebrowser.cgi to make it work really well
Fri Feb 4 00:38:17 2005 UTC (15 years, 4 months ago) by redwards
Changes since 1.3: +3 -4 lines
More changes to raedraw/genomebrowser.cgi to get tag/vals working properly. They do now.
Revision 1.3 - (view) (download) (annotate) - [selected]
Thu Feb 3 19:36:47 2005 UTC (15 years, 4 months ago) by redwards
Changes since 1.2: +20 -5 lines
Added support for tag/value pairs to genomebrowser.cgi/raedraw.cgi
Wed Feb 2 22:08:56 2005 UTC (15 years, 4 months ago) by redwards
Changes since 1.1: +4 -3 lines
Minor corrections to SVG genome browser
Wed Feb 2 21:02:32 2005 UTC (15 years, 4 months ago) by redwards
Diff to selected 1.3
genomebrowser.cgi is the first script to use raedraw and to make comparisons of genomes.
In the first version it only draws sims between multiple genomes. In subsequent versions I will extend
it to include all tag value pairs.
