[Bio] / FigWebServices / genome_statistics.cgi Repository:
Log of /FigWebServices/genome_statistics.cgi
Links to caBIG-00-00-00: (view) (download) (annotate)
Revision 1.32 - (view) (download) (annotate) - [select for diffs]
Fri Nov 4 21:51:41 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.31: +22 -3 lines
Diff to previous 1.31
inactivating attributes
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Tue Oct 18 23:33:30 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.30: +9 -9 lines
Diff to previous 1.30
minor fix to genome_statistics.cgi
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Mon Oct 10 19:28:45 2005 UTC (14 years, 5 months ago) by efrank
Changes since 1.29: +15 -5 lines
Diff to previous 1.29
Don't assume there are any assignments for an organism.  This fixes
a divide by zero error.
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Sun Sep 18 14:11:22 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.28: +2 -1 lines
Diff to previous 1.28
fixes on showing subsystems
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Sun Sep 18 01:20:28 2005 UTC (14 years, 6 months ago) by overbeek
Diff to previous 1.27
fixes to display_subsys.cgi
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Thu Sep 15 19:13:20 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.26: +29 -2 lines
Diff to previous 1.26
Make genome_statistics ignore subsystem entries that have variant=-1.
Sun Sep 11 17:02:41 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.25: +5 -2 lines
Diff to previous 1.25
fixes to display of reactions
Sun Sep 11 16:34:41 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.24: +5 -1 lines
Diff to previous 1.24
add functiontion to FIG.pm to get active subsystems for a genome
Tue Aug 16 19:40:15 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.23: +33 -0 lines
Diff to previous 1.23
NMPDR updates.
Wed Aug 10 17:13:45 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.22: +9 -0 lines
Diff to previous 1.22
fixes to displaying reactions and status of models
Wed Aug 10 16:17:52 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.21: +4 -4 lines
Diff to previous 1.21
fixes to showing reactions
Tue Aug 9 18:12:16 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.20: +67 -1 lines
Diff to previous 1.20
added show_reactions
Tue Aug 9 14:44:58 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.19: +14 -3 lines
Diff to previous 1.19
improvements to showing subsystems for an organism
Tue Aug 9 14:25:11 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.18: +32 -68 lines
Diff to previous 1.18
Thu Aug 4 22:35:28 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.17: +37 -13 lines
Diff to previous 1.17
Counting subsystems
Thu Aug 4 21:06:05 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.16: +28 -0 lines
Diff to previous 1.16
subsys by genomes
Sun Jul 10 18:17:42 2005 UTC (14 years, 8 months ago) by golsen
Changes since 1.15: +48 -19 lines
Add project description to genome statistics report.
Format PEG statistics as a table (easier to read).
Add title to "Statistics Page" when no genome is selected.
Some minor code clean up.
Wed Apr 13 16:38:11 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.14: +2 -1 lines
better stats
Wed Apr 13 15:37:30 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.13: +15 -0 lines
changed genome stats to show attributes
Fri Apr 8 20:22:23 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.12: +13 -13 lines
changed tag/value pairs completely. Ooops!
Sat Mar 5 00:31:36 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.11: +8 -3 lines
minor changes to oa in genome stats
Fri Mar 4 18:29:21 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.10: +1 -0 lines
Added attribute editing to the protein.cgi page
Fri Mar 4 06:22:10 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.9: +117 -0 lines
Big updates to FIG.pm for the addition of methods to properly handle attributes. Also modified genome_statistics to take advantage of these new methods. load_attributes will load genomes and other attributes but doesn't not yet use the new methods (but should), and Attributes.html is some docs.
Fri Jan 14 13:56:37 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.8: +41 -1 lines
additional statistics
Mon Jan 10 13:09:01 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.7: +71 -24 lines
add some statistics capabilities
Sat Dec 18 13:03:01 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.6: +2 -2 lines
Fix typo in page title.
Wed Oct 27 02:51:43 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.5: +111 -19 lines
genome_statistics.cgi is completed
Tue Oct 26 14:01:00 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.4: +71 -2 lines
minor advances in genome_statistics.cgi
Sun Oct 24 02:45:41 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.3: +33 -7 lines
minor additions to genome statistics
Sat Oct 23 21:41:38 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.2: +27 -2 lines
stupid error in FIG.pm
Sat Oct 23 21:28:54 2004 UTC (15 years, 5 months ago) by overbeek
minor fix
Sat Oct 23 19:51:41 2004 UTC (15 years, 5 months ago) by overbeek
introduce genome statistics
