[Bio] / FigWebServices / genome_object.cgi Repository:
Log of /FigWebServices/genome_object.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Fri Jul 11 19:15:39 2014 UTC (5 years, 6 months ago) by olson
CVS Tags: rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.1: +108 -19 lines
RAST fixes.
Tue May 6 19:26:48 2014 UTC (5 years, 8 months ago) by olson
Add support for retrieving a KB genome object from SEED
