[Bio] / FigWebServices / figfam_proto.cgi Repository:
Log of /FigWebServices/figfam_proto.cgi
Links to mgrast_rel_2008_1110_v2: (view) (download) (annotate)
Fri May 25 16:40:29 2007 UTC (12 years, 6 months ago) by mkubal
Changes since 1.5: +23 -14 lines
added ss info
Thu May 24 20:54:25 2007 UTC (12 years, 6 months ago) by mkubal
Changes since 1.4: +24 -13 lines
052407
Thu May 24 20:09:42 2007 UTC (12 years, 6 months ago) by mkubal
Changes since 1.3: +150 -55 lines
052407
Tue Feb 27 21:06:16 2007 UTC (12 years, 9 months ago) by mkubal
Changes since 1.2: +68 -22 lines
latest
Thu Feb 22 23:06:08 2007 UTC (12 years, 9 months ago) by mkubal
Changes since 1.1: +24 -14 lines
faster
Thu Feb 22 20:45:16 2007 UTC (12 years, 9 months ago) by mkubal
prototype domain analysis of protein sets
