[Bio] / FigWebServices / extend_subsys.cgi Repository:
Log of /FigWebServices/extend_subsys.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Sat Aug 23 23:39:22 2008 UTC (11 years, 6 months ago) by golsen
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.12: +5 -14 lines
Move writing of assignment annotation from a case-by-case basis (and it
was missing in several key places) to the FIG::assign_function.
Modify the code in each of the calling locations to not make duplicate
annotations.
At the same time, remove (most) of the instances of making different
calls to assign_function depending on the user name.  assign_function
treats everyone as master (but writes an annotation with the real user
name).
Mon Sep 4 20:09:55 2006 UTC (13 years, 5 months ago) by redwards
using is_environmental
Mon Dec 5 19:12:12 2005 UTC (14 years, 2 months ago) by olson
Changes since 1.10: +17 -0 lines
add license words
Fri Apr 29 20:44:43 2005 UTC (14 years, 9 months ago) by overbeek
fix extend_subsys to not allow false forward
Thu Feb 24 12:56:55 2005 UTC (15 years ago) by overbeek
extend variants of 0
Thu Feb 24 12:10:12 2005 UTC (15 years ago) by overbeek
Changes since 1.7: +7 -1 lines
Sat Feb 12 04:14:11 2005 UTC (15 years ago) by overbeek
Changes since 1.6: +0 -2 lines
remove minor stupidity
Sat Feb 12 04:01:01 2005 UTC (15 years ago) by overbeek
Changes since 1.5: +5 -3 lines
many fixes to extending subsystems
Fri Feb 11 15:33:50 2005 UTC (15 years ago) by overbeek
add UniProt funcs to extend_subsys.cgi
Fri Feb 11 15:21:35 2005 UTC (15 years ago) by overbeek
Changes since 1.3: +16 -7 lines
add columns to extend_subsys.cgi
Mon Jan 31 14:01:07 2005 UTC (15 years ago) by overbeek
add pegs_in_subsystems
Thu Jan 27 18:28:29 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.1: +1 -43 lines
fix extend_subsys.cgi
Fri Jan 21 11:27:26 2005 UTC (15 years, 1 month ago) by heiko
initial checkin
interactive script for
