[Bio] / FigWebServices / extend_subsys.cgi Repository:
Log of /FigWebServices/extend_subsys.cgi
Links to merge-trunktag-bobdev_news-2: (view) (download) (annotate)
Fri Apr 29 20:44:43 2005 UTC (14 years, 11 months ago) by overbeek
fix extend_subsys to not allow false forward
Thu Feb 24 12:56:55 2005 UTC (15 years, 1 month ago) by overbeek
extend variants of 0
Thu Feb 24 12:10:12 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.7: +7 -1 lines
Sat Feb 12 04:14:11 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.6: +0 -2 lines
remove minor stupidity
Sat Feb 12 04:01:01 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.5: +5 -3 lines
many fixes to extending subsystems
Fri Feb 11 15:33:50 2005 UTC (15 years, 2 months ago) by overbeek
add UniProt funcs to extend_subsys.cgi
Fri Feb 11 15:21:35 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.3: +16 -7 lines
add columns to extend_subsys.cgi
Mon Jan 31 14:01:07 2005 UTC (15 years, 2 months ago) by overbeek
add pegs_in_subsystems
Thu Jan 27 18:28:29 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.1: +1 -43 lines
fix extend_subsys.cgi
Fri Jan 21 11:27:26 2005 UTC (15 years, 2 months ago) by heiko
initial checkin
interactive script for
