[Bio] / FigWebServices / ex_assertions.cgi Repository:
Log of /FigWebServices/ex_assertions.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Wed Feb 4 17:47:24 2009 UTC (10 years, 11 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
add check for cluster-based
Wed Feb 4 17:34:09 2009 UTC (10 years, 11 months ago) by overbeek
disconnect check of is_cluster_based
Wed Feb 4 17:29:14 2009 UTC (10 years, 11 months ago) by overbeek
fix typo in testing aux roles
Thu Jan 29 01:18:03 2009 UTC (10 years, 11 months ago) by overbeek
CVS Tags: rast_rel_2009_02_05
do not consider aux roles
Sun Jan 25 17:34:13 2009 UTC (10 years, 11 months ago) by overbeek
make ex_assertions.cgi ignore inactive variants
Fri Jan 23 14:09:02 2009 UTC (10 years, 11 months ago) by overbeek
fix to sim check
Fri Jan 23 03:47:02 2009 UTC (10 years, 11 months ago) by overbeek
Changes since 1.4: +140 -28 lines
full version of ex_assertions.cgi
Thu Jan 22 12:00:33 2009 UTC (10 years, 11 months ago) by overbeek
Changes since 1.3: +87 -47 lines
fixes to ex_assertions.cgi
Thu Jan 22 02:38:09 2009 UTC (10 years, 11 months ago) by overbeek
remove aux roles
Thu Jan 22 02:33:57 2009 UTC (10 years, 11 months ago) by overbeek
remove aux roles
Tue Jan 20 20:12:04 2009 UTC (10 years, 11 months ago) by overbeek
add cgi script to help construct expert assertions
