[Bio] / FigWebServices / diffsF.cgi Repository:
Log of /FigWebServices/diffsF.cgi
Links to rast_rel_2010_0928: (view) (download) (annotate)
Revision 1.8 - (view) (download) (annotate) - [selected]
Sat Mar 1 15:36:53 2008 UTC (12 years, 3 months ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_release_2008_09_29
change ::data/FigfamsData to ::FigfamsData
Wed Oct 18 23:12:25 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.6: +163 -54 lines
Fixed &show_alignment() bugs. -- /gdp
Wed Oct 18 09:12:24 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.5: +48 -28 lines
Fixed a number of bugs, but still not there yet... -- /gdp
Wed Oct 18 07:38:44 2006 UTC (13 years, 7 months ago) by overbeek
Added debug information if search for gene fails. -- /gdp
Wed Oct 18 07:24:04 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.3: +90 -23 lines
First attempt at providing alignments. -- /gdp
Wed Oct 18 02:43:53 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.2: +29 -10 lines
Modified to sort length differences in descending order. -- /gdp
Fri Oct 6 07:14:45 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.1: +28 -3 lines
Added feature lengths to the table, and whether a feature has shortened or lengthened. -- /gdp
Thu Oct 5 00:28:58 2006 UTC (13 years, 8 months ago) by overbeek
Diff to selected 1.8
fixes to rapid prop technology and added diffsF.cgi
