Log of /FigWebServices/cv.cgi
Parent Directory
Revision
1.16 -
view)
download)
annotate)
[select for diffs]
Mon Dec 5 19:12:12 2005 UTC (14 years ago) by
olson
Branch:
MAIN
CVS Tags:
HEAD,
caBIG-05Apr06-00,
caBIG-13Feb06-00,
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_rel_2008_0625,
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
myrast_rel40,
rast_2008_0924,
rast_rel_2008_04_23,
rast_rel_2008_06_16,
rast_rel_2008_06_18,
rast_rel_2008_07_21,
rast_rel_2008_08_07,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912,
rast_release_2008_09_29
Changes since
1.15: +17 -0 lines
Diff to
previous 1.15
add license words
Revision
1.15 -
view)
download)
annotate)
[select for diffs]
Thu Nov 10 20:18:17 2005 UTC (14 years, 1 month ago) by
efrank
Branch:
MAIN
CVS Tags:
caBIG-00-00-00
Changes since
1.14: +1 -1 lines
Diff to
previous 1.14
migrate cv files from Global to Global/CV. actually, this is bogus and
hidden in FIG.pm but there was a random commented line of code pointing
to old location so i changed it.
Revision
1.14 -
view)
download)
annotate)
[select for diffs]
Thu Nov 10 19:58:45 2005 UTC (14 years, 1 month ago) by
efrank
Branch:
MAIN
Changes since
1.13: +15 -15 lines
Diff to
previous 1.13
migrate to follow change in FIG.pm encapsulating via search_cv_file.
also have mods to index.cgi not committing now. hope this doesn't
break.
Revision
1.4 -
view)
download)
annotate)
[select for diffs]
Thu Oct 20 00:44:11 2005 UTC (14 years, 1 month ago) by
efrank
Branch:
MAIN
Changes since
1.3: +21 -17 lines
Diff to
previous 1.3
-improved error message prsenatation/handling
-vocab file now expected to be of form cv_search_<vocabName>.txt, e.g.,
cv_search_GO.txt
still probs- multiple entries of same term
deleting on term from vocab deletes all
Revision
1.3 -
view)
download)
annotate)
[select for diffs]
Thu Oct 20 00:26:29 2005 UTC (14 years, 1 month ago) by
efrank
Branch:
MAIN
Changes since
1.2: +163 -159 lines
Diff to
previous 1.2
getting closer. many fixes.
- merged two almost same show_init and show_search into a common build page.
- broke form into 3 forms so that textfields couple to correct submit buttons
- some improved testing on input, e.g., do not add custom CV if not all 3
items are provided
- say what peg we're on
- make add button go away if no search results returned (afraid of corner case
of it getting thwapped)
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
