[Bio] / FigWebServices / cv.cgi Repository:
Log of /FigWebServices/cv.cgi
Links to mgrast_rel_2008_0923: (view) (download) (annotate)
Mon Dec 5 19:12:12 2005 UTC (14 years, 2 months ago) by olson
Changes since 1.15: +17 -0 lines
add license words
Thu Nov 10 20:18:17 2005 UTC (14 years, 3 months ago) by efrank
CVS Tags: caBIG-00-00-00
migrate cv files from Global to Global/CV.  actually, this is bogus and
hidden in FIG.pm but there was a random commented line of code pointing
to old location so i changed it.
Thu Nov 10 19:58:45 2005 UTC (14 years, 3 months ago) by efrank
Changes since 1.13: +15 -15 lines
migrate to follow change in FIG.pm encapsulating via search_cv_file.
also have mods to index.cgi not committing now.  hope this doesn't
break.
Mon Oct 31 05:01:37 2005 UTC (14 years, 3 months ago) by mkubal
Changes since 1.12: +7 -7 lines
manual add fixed
Thu Oct 27 15:03:15 2005 UTC (14 years, 3 months ago) by efrank
add hugo
Wed Oct 26 20:09:56 2005 UTC (14 years, 3 months ago) by mkubal
Changes since 1.10: +32 -11 lines
latest from Mike add_term error checking needs work
Wed Oct 26 17:45:01 2005 UTC (14 years, 3 months ago) by efrank
Changes since 1.9: +6 -6 lines
fix : -> ; and missing > on an href
Tue Oct 25 01:56:45 2005 UTC (14 years, 3 months ago) by mkubal
Changes since 1.8: +2 -2 lines
user param fixed when passed to protein.cgi
Mon Oct 24 20:00:07 2005 UTC (14 years, 3 months ago) by mkubal
Changes since 1.7: +27 -12 lines
it's even better
Sat Oct 22 18:38:21 2005 UTC (14 years, 4 months ago) by mkubal
Changes since 1.6: +94 -82 lines
requires user name to edit
Fri Oct 21 22:27:40 2005 UTC (14 years, 4 months ago) by mkubal
Changes since 1.5: +27 -11 lines
delete works
Thu Oct 20 00:57:14 2005 UTC (14 years, 4 months ago) by efrank
Changes since 1.4: +1 -4 lines
too agressive.  one fatal error was actually an ok case
Thu Oct 20 00:44:11 2005 UTC (14 years, 4 months ago) by efrank
Changes since 1.3: +21 -17 lines
-improved error message prsenatation/handling
-vocab file now expected to be of form cv_search_<vocabName>.txt, e.g.,
 cv_search_GO.txt
still probs- multiple entries of same term
             deleting on term from vocab deletes all
Thu Oct 20 00:26:29 2005 UTC (14 years, 4 months ago) by efrank
Changes since 1.2: +163 -159 lines
getting closer.  many fixes.
- merged two almost same show_init and show_search into a common build page.
- broke form into 3 forms so that textfields couple to correct submit buttons
- some improved testing on input, e.g., do not add custom CV if not all 3
  items are provided
- say what peg we're on
- make add button go away if no search results returned (afraid of corner case
  of it getting thwapped)
Wed Oct 19 20:20:07 2005 UTC (14 years, 4 months ago) by mkubal
Changes since 1.1: +92 -33 lines
best cv.cgi yet
Wed Oct 19 14:39:06 2005 UTC (14 years, 4 months ago) by mkubal
controlled vocabulary iface- still coming to life.
