[Bio] / FigWebServices / comp_genomes.cgi Repository:
Log of /FigWebServices/comp_genomes.cgi
Links to rast_rel_2008_06_16: (view) (download) (annotate)
Tue Apr 29 08:02:59 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.9: +2 -1 lines
Added tracing support.
Fri Mar 21 19:19:46 2008 UTC (11 years, 11 months ago) by overbeek
CVS Tags: rast_rel_2008_04_23
Changes since 1.8: +21 -4 lines
allow the genome-cache to move around
Wed Mar 19 12:47:40 2008 UTC (11 years, 11 months ago) by overbeek
Changes since 1.7: +8 -8 lines
fixes to support comparing genomes under RAST
Fri Mar 7 03:37:58 2008 UTC (11 years, 11 months ago) by overbeek
Changes since 1.6: +64 -0 lines
add the ability to call comp_genomes.cgi without arguments
Sat Feb 2 21:17:05 2008 UTC (12 years ago) by golsen
Changes since 1.5: +169 -134 lines
Add a new selection tool for the reference genome, and for ordering the
display of the remaining genomes.
Fix a bug that lost some genomes in the comparison.
Thu Apr 12 19:07:12 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.4: +19 -4 lines
changes to comp_genomes.cgi to support rast genomes
Thu Apr 12 04:36:54 2007 UTC (12 years, 10 months ago) by overbeek
fixes to the comparison of genomes - cache_comparison_data
Mon Apr 9 15:12:11 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.2: +118 -2 lines
fixes to Gary's comparison of genomes
Sun Apr 8 23:21:03 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.1: +41 -5 lines
enhancements to Gary's genome comparison tool
Sun Apr 8 21:36:16 2007 UTC (12 years, 10 months ago) by overbeek
add Gary's compare genome stuff
