[Bio] / FigWebServices / comp_MR.cgi Repository:
Log of /FigWebServices/comp_MR.cgi
Links to rast_rel_2010_0827: (view) (download) (annotate)
Tue Apr 3 12:24:31 2007 UTC (13 years ago) by overbeek
fixed to comp_MR.cgi and FIGV.pm
Mon Mar 12 21:58:58 2007 UTC (13 years ago) by paarmann
Changes since 1.2: +79 -11 lines
added links to seed viewer
added find similar pegs function
Mon Mar 12 01:13:24 2007 UTC (13 years ago) by overbeek
Changes since 1.1: +41 -9 lines
basic ability to compare metabolic reconstructions
Sun Mar 11 20:37:54 2007 UTC (13 years ago) by overbeek
basic stuff for comparing metabolic reconstructions
