[Bio] / FigWebServices / cluster_xmlrpc.cgi Repository:
Log of /FigWebServices/cluster_xmlrpc.cgi
Revision 1.2 - (view) (download) (annotate) - [selected]
Mon Dec 5 19:12:11 2005 UTC (14 years ago) by olson
add license words
Thu Feb 10 16:56:24 2005 UTC (14 years, 10 months ago) by olson
Diff to selected 1.2
XMLRPC interface to cluster job mgr.
