[Bio] / FigWebServices / close_genome_discrepancies.cgi Repository:
Log of /FigWebServices/close_genome_discrepancies.cgi
Links to mgrast_dev_02222011: (view) (download) (annotate)
Thu Sep 21 19:03:21 2006 UTC (13 years, 9 months ago) by redwards
Changes since 1.7: +4 -4 lines
minor updates to ev code and default params
Revision 1.7 - (view) (download) (annotate) - [selected]
Thu Jun 29 22:43:41 2006 UTC (14 years ago) by overbeek
Changes since 1.6: +5 -3 lines
RAE: correcting progress meter
Thu Jun 29 19:08:12 2006 UTC (14 years ago) by overbeek
RAE: Adding percent so far
Thu Jun 29 18:52:57 2006 UTC (14 years ago) by overbeek
Changes since 1.4: +6 -2 lines
Thu Jun 29 18:00:55 2006 UTC (14 years ago) by overbeek
Changes since 1.3: +21 -1 lines
RAE: adding genome walking information
Thu Jun 29 16:17:42 2006 UTC (14 years ago) by overbeek
Changes since 1.2: +10 -5 lines
RAE: add genome counts
Thu Jun 29 15:36:01 2006 UTC (14 years ago) by overbeek
RAE: correct ss display
Thu Jun 29 15:21:59 2006 UTC (14 years ago) by overbeek
Diff to selected 1.7
RAE: web page for finding diffs between similar genomes
