[Bio] / FigWebServices / cleanup.cgi Repository:
Log of /FigWebServices/cleanup.cgi
Fri Jan 9 19:39:02 2009 UTC (10 years, 10 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
add sizes to tables
Fri Jan 9 18:45:41 2009 UTC (10 years, 10 months ago) by overbeek
Changes since 1.2: +11 -4 lines
add sizes to tables
Tue Jan 6 13:26:27 2009 UTC (10 years, 10 months ago) by overbeek
seprate target windows
Sun Jan 4 22:44:17 2009 UTC (10 years, 10 months ago) by overbeek
add script for annotators to clean up bad spots
