[Bio] / FigWebServices / chromosomal_clusters_old.cgi Repository:
Log of /FigWebServices/chromosomal_clusters_old.cgi
Fri Jul 28 02:07:28 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.1: +31 -31 lines
Changed to use the new PageBuilder call signature.
Thu Jun 22 19:32:00 2006 UTC (13 years, 4 months ago) by overbeek
Install new chromosmal_clusters that uses the server-cached data.
