[Bio] / FigWebServices / check_variants.cgi Repository:
Log of /FigWebServices/check_variants.cgi
Links to rast_rel_2009_0925: (view) (download) (annotate)
Thu Mar 20 12:32:41 2008 UTC (12 years, 2 months ago) by overbeek
Changes since 1.10: +6 -6 lines
allow different format for roles, rules and definitions in check_variants.cgi
Wed Mar 19 22:15:27 2008 UTC (12 years, 2 months ago) by overbeek
Changes since 1.9: +4 -3 lines
change role_to_pegs to prots_for_role in check_variants.cgi, since you are looking for pegs that are not in subsystems
Tue Oct 23 15:32:14 2007 UTC (12 years, 7 months ago) by overbeek
minor bug in check_variants.cgi
Tue Oct 23 14:57:48 2007 UTC (12 years, 7 months ago) by overbeek
Thu Oct 11 20:51:56 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.6: +7 -5 lines
fix check_variants.cgi definition of n of set
Thu Oct 11 20:15:00 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.5: +75 -45 lines
handle errors in check_variants.cgi somewhat more gracefully
Wed Oct 10 18:25:43 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.4: +2 -1 lines
die on the failed to parse error
Sat Oct 6 16:25:40 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.3: +0 -1 lines
reset check_variants.cgi to running version
Sat Oct 6 16:24:44 2007 UTC (12 years, 7 months ago) by overbeek
fix to display_subsys.cgi when focus is on an incomplete genome
Fri Oct 5 18:44:20 2007 UTC (12 years, 7 months ago) by overbeek
fix minor bug in check_variants.cgi
Fri Oct 5 18:41:16 2007 UTC (12 years, 7 months ago) by overbeek
add check_variants.cgi, a program to automatically validate variant codes
