[Bio] / FigWebServices / check_subsys.cgi Repository:
Log of /FigWebServices/check_subsys.cgi
Links to mgrast_dev_02212011: (view) (download) (annotate)
Thu Aug 9 12:07:18 2007 UTC (12 years, 7 months ago) by overbeek
Diff to previous 1.25
attempt to fix some of the mistakes introduced into check_subsys.cgi
Mon Feb 5 23:34:46 2007 UTC (13 years, 1 month ago) by overbeek
Changes since 1.24: +2 -0 lines
Diff to previous 1.24
fixes to checking subsystems
Thu Feb 1 14:58:06 2007 UTC (13 years, 1 month ago) by overbeek
Changes since 1.23: +9 -1 lines
Diff to previous 1.23
strip comments on functions for subsystem checking
Fri Jan 19 17:13:45 2007 UTC (13 years, 2 months ago) by olson
Changes since 1.22: +4 -2 lines
Diff to previous 1.22
add URI escaping
Tue Jan 9 21:38:22 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.21: +1 -0 lines
Diff to previous 1.21
fixes to checking in check_subsys.cgi and subsys.cgi
Tue Jan 9 21:18:14 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.20: +4 -4 lines
Diff to previous 1.20
handle parens in file names in subsys.cgi check_subsys.cgi
Tue Jan 9 02:39:15 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.19: +8 -1 lines
Diff to previous 1.19
changes to showing summary of checked subsystems
Tue Jan 9 02:21:03 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.18: +47 -5 lines
Diff to previous 1.18
add subsystem checking summaries
Wed Jan 3 03:35:33 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.17: +1 -2 lines
Diff to previous 1.17
fix in checking subsystems
Tue Jan 2 04:03:20 2007 UTC (13 years, 2 months ago) by overbeek
Changes since 1.16: +10 -0 lines
Diff to previous 1.16
more fixes on counting left-out PEGs
Mon Jan 1 01:18:02 2007 UTC (13 years, 3 months ago) by overbeek
Changes since 1.15: +7 -2 lines
Mon Jan 1 00:09:07 2007 UTC (13 years, 3 months ago) by overbeek
fix sort order, second try
Mon Jan 1 00:04:54 2007 UTC (13 years, 3 months ago) by overbeek
Changes since 1.13: +1 -9 lines
change sort order on proposed genomes in check_subsys.cgi
Sun Dec 31 23:45:17 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.12: +23 -1 lines
add predictions of new genomes to check_subsys.cgi
Sun Dec 31 23:30:44 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.11: +42 -20 lines
initial rewrite of subsystem checking stuff
Fri Jan 13 20:22:40 2006 UTC (14 years, 2 months ago) by overbeek
fixes to deleted_features, replace_features_with, etc
Mon Dec 5 19:12:11 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.9: +17 -0 lines
add license words
Wed Nov 2 16:31:24 2005 UTC (14 years, 4 months ago) by olson
CVS Tags: caBIG-00-00-00
use run_gathering_output instead of backticks; this adds a bit of security and removes the
crash when subsystem name contains parentheses.
Fri Jun 17 19:38:31 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.7: +1 -0 lines
subsys.cgi now does an initial check_subsys.cgi
Wed Apr 6 15:32:09 2005 UTC (14 years, 11 months ago) by redwards
CVS Tags: Root-bobdev_news
hide -1 variants in subsys.cgi
Wed Apr 6 03:17:59 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.5: +3 -6 lines
backing off a change to check_subsys
Wed Apr 6 01:01:22 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.4: +8 -4 lines
added change annotation by function to check subsys.cgi
Wed Dec 8 23:18:01 2004 UTC (15 years, 3 months ago) by redwards
Changes since 1.3: +15 -6 lines
Changes to fid_checked.cgi and check_subsys.cgi to allow you to update annotations in subsystems from the check subsystems page.
Wed Dec 8 20:22:20 2004 UTC (15 years, 3 months ago) by redwards
Changes since 1.2: +13 -3 lines
Added "other subsystems" columns to tables in check_subsys.cgi
Sun Dec 5 16:35:16 2004 UTC (15 years, 3 months ago) by overbeek
Changes since 1.1: +5 -0 lines
add checking for subsystems
Sun Dec 5 14:01:53 2004 UTC (15 years, 3 months ago) by overbeek
fix to help for seqs_with_role
