[Bio] / FigWebServices / check_subsys.cgi Repository:
Diff of /FigWebServices/check_subsys.cgi
revision 1.10, Mon Dec 5 19:12:11 2005 UTC revision 1.11, Fri Jan 13 20:22:40 2006 UTC
# Line 131  Line 131
131
132      my $user=$cgi->param('user');      my $user=$cgi->param('user');
133      my @raw_output = &FIG::run_gathering_output("$FIG_Config::bin/check_subsystems", $subsys);      my @raw_output = &FIG::run_gathering_output("$FIG_Config::bin/check_subsystems", $subsys);
134      warn "Got raw output @raw_output\n";  #   warn "Got raw output @raw_output\n";
135      my @checked = map { chop; [split(/\t/,$_)] } @raw_output;      my @checked = map { chop; [split(/\t/,$_)] } @raw_output;
136      # RAE: it only makes sense to have Assign Role in column 1, so I duplicate this instead of leaving the column empty. Blah.      # RAE: it only makes sense to have Assign Role in column 1, so I duplicate this instead of leaving the column empty. Blah.
137      $col_hdrs1 = ["PEG","Function","Role","Assign Role","Other Subsystems","Genome"];      $col_hdrs1 = ["PEG","Function","Role","Assign Role","Other Subsystems","Genome"];
Legend:
Removed from v.1.10
changed lines
  Added in v.1.11
