[Bio] / FigWebServices / check_anno.cgi Repository:
Log of /FigWebServices/check_anno.cgi
Links to mgrast_dev_04012011: (view) (download) (annotate)
Thu Jan 26 04:18:27 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.1: +5 -4 lines
fix numbers on chedck_anno.cgi
Thu Jan 26 03:36:47 2006 UTC (13 years, 10 months ago) by overbeek
add check_anno.cgi
