[Bio] / FigWebServices / check_anno.cgi Repository:
Log of /FigWebServices/check_anno.cgi
Links to mgrast_rel_2008_1110: (view) (download) (annotate)
Revision 1.2 - (view) (download) (annotate) - [selected]
Thu Jan 26 04:18:27 2006 UTC (14 years, 5 months ago) by overbeek
Changes since 1.1: +5 -4 lines
fix numbers on chedck_anno.cgi
Thu Jan 26 03:36:47 2006 UTC (14 years, 5 months ago) by overbeek
Diff to selected 1.2
add check_anno.cgi
