[Bio] / FigWebServices / bbhs.cgi Repository:
Log of /FigWebServices/bbhs.cgi
Wed Dec 6 02:03:42 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.3: +7 -6 lines
Changed so that the local datbase is opened if the current HTTP HOST is not a bio server. I'm not sure that's the correct approach.
Wed Dec 6 01:30:39 2006 UTC (12 years, 11 months ago) by parrello
Changes since 1.2: +37 -7 lines
Modified to allow the batch processing required by the signature genes tool. Basically, you can specify a pattern instead of a feature ID, and you can restrict the returns to a list of target genomes. The old functionality should work unmodified, however.
Thu Aug 31 19:48:30 2006 UTC (13 years, 2 months ago) by olson
tweak to bbhs server
Thu Aug 31 19:20:28 2006 UTC (13 years, 2 months ago) by olson
Added bbhs server code
