[Bio] / FigWebServices / att2sub.cgi Repository:
Log of /FigWebServices/att2sub.cgi
Links to mgrast_release_3_0_3: (view) (download) (annotate)
Mon Dec 5 19:12:11 2005 UTC (14 years, 3 months ago) by olson
add license words
Wed Oct 12 21:03:16 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Mon Aug 1 16:29:22 2005 UTC (14 years, 8 months ago) by olson
Replace use of $FIG_Config::cgi_url with &FIG::cgi_url()
Revision 1.3 - (view) (download) (annotate) - [selected]
Sun Jul 24 19:31:59 2005 UTC (14 years, 8 months ago) by mkubal
improved att2sub
Sun Jul 24 19:20:06 2005 UTC (14 years, 8 months ago) by mkubal
Changes since 1.1: +5 -3 lines
improved att2sub
Sun Jul 24 15:55:28 2005 UTC (14 years, 8 months ago) by mkubal
Diff to selected 1.3
map atts to ss
