[Bio] / FigWebServices / assignments.cgi Repository:
Log of /FigWebServices/assignments.cgi
Links to rast_rel_2008_04_23: (view) (download) (annotate)
Sat Aug 19 22:29:15 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.15: +2 -0 lines
add potentially_missed_assignments
Mon Dec 5 19:12:11 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.14: +17 -0 lines
add license words
Wed Oct 12 21:03:16 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.13: +5 -5 lines
Sun Jan 23 16:54:49 2005 UTC (15 years, 2 months ago) by overbeek
Changes since 1.12: +16 -14 lines
fix the assignment set processing
Mon Oct 18 21:30:35 2004 UTC (15 years, 5 months ago) by redwards
Changes since 1.11: +9 -3 lines
Minor updates to assignments.cgi to add links so that once you accept a subset
you can delete it from the pending set and return to the accept/examine page
Wed Sep 22 22:18:35 2004 UTC (15 years, 6 months ago) by redwards
Changes since 1.10: +8 -4 lines
Altered assignments.cgi to include an accept/edit/examine button at the bottom of the edit/examine page
Fri Jun 4 20:40:21 2004 UTC (15 years, 10 months ago) by olson
make table clearer
Tue May 25 17:27:49 2004 UTC (15 years, 10 months ago) by olson
fix typo.
Mon Apr 19 11:36:40 2004 UTC (15 years, 11 months ago) by overbeek
fix a bad bug in assignment permissions
Fri Apr 2 18:02:20 2004 UTC (16 years ago) by overbeek
Changes since 1.6: +2 -2 lines
add a new version of the spreadsheet software
Sun Feb 29 01:53:39 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.5: +16 -14 lines
fixes to spreadsheet
Mon Feb 16 18:23:08 2004 UTC (16 years, 1 month ago) by overbeek
fixes to assignments.cgi
Tue Feb 10 18:44:58 2004 UTC (16 years, 2 months ago) by overbeek
try to fix importing assignments (the user)
Tue Feb 3 23:08:53 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.2: +15 -1 lines
fix translation rules
Fri Jan 16 14:59:48 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.1: +113 -47 lines
add ability to process assignment sets
Wed Jan 14 20:20:32 2004 UTC (16 years, 2 months ago) by overbeek
synch up Ross
