[Bio] / FigWebServices / assign_using_tree.cgi Repository:
Log of /FigWebServices/assign_using_tree.cgi
Links to mgrast_release_3_1_2: (view) (download) (annotate)
Sat Aug 23 23:39:22 2008 UTC (11 years, 6 months ago) by golsen
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.16: +5 -12 lines
Diff to previous 1.16
Move writing of assignment annotation from a case-by-case basis (and it
was missing in several key places) to the FIG::assign_function.
Modify the code in each of the calling locations to not make duplicate
annotations.
At the same time, remove (most) of the instances of making different
calls to assign_function depending on the user name.  assign_function
treats everyone as master (but writes an annotation with the real user
name).
Thu Apr 17 18:32:19 2008 UTC (11 years, 10 months ago) by disz
Changes since 1.15: +20 -7 lines
Display subsystems on hover
Tue Mar 25 17:31:54 2008 UTC (11 years, 10 months ago) by disz
Changes since 1.14: +69 -7 lines
Additions for the JAVA tree based annotations
Mon Mar 10 21:51:29 2008 UTC (11 years, 11 months ago) by overbeek
Changes since 1.13: +7 -8 lines
weed out deleted PEGs from tree based annotation
Mon Mar 10 21:41:01 2008 UTC (11 years, 11 months ago) by overbeek
Changes since 1.12: +8 -0 lines
Fri Sep 7 21:06:04 2007 UTC (12 years, 5 months ago) by overbeek
Changes since 1.11: +39 -1 lines
allow resetting trees in processing alignments/trees
Wed Aug 8 18:55:52 2007 UTC (12 years, 6 months ago) by overbeek
strip comments when collapsing trees
Wed Aug 8 18:43:37 2007 UTC (12 years, 6 months ago) by overbeek
Changes since 1.9: +1 -0 lines
Wed Jul 18 02:18:24 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.8: +5 -1 lines
show in subsystems for tree-based annotation
Sun Jul 15 16:22:31 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.7: +58 -0 lines
support displaying alignments dueing tree-based annotation
Sun Jul 15 04:08:16 2007 UTC (12 years, 7 months ago) by overbeek
Changes since 1.6: +27 -16 lines
allow acces to alignment library from protein page
Wed Jan 11 02:55:44 2006 UTC (14 years, 1 month ago) by overbeek
Changes since 1.5: +126 -6 lines
fixes to assign_using
Mon Dec 5 19:12:11 2005 UTC (14 years, 2 months ago) by olson
add license words
Sun Jun 19 14:03:43 2005 UTC (14 years, 8 months ago) by overbeek
CVS Tags: caBIG-00-00-00, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
minor fix to rerooting in assign_using_tree.cgi
Sun Jun 19 13:06:21 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.2: +75 -71 lines
fix to assign_using_tree.cgi - check for tree before parsing
Tue May 10 12:03:39 2005 UTC (14 years, 9 months ago) by overbeek
CVS Tags: Root-bobdev_news
Changes since 1.1: +54 -35 lines
fixes to using trees under subsystems
Tue Nov 16 03:29:35 2004 UTC (15 years, 3 months ago) by overbeek
add assign_using_tree and fix overlays in pinned regions
