[Bio] / FigWebServices / anno_server.cgi Repository:
Log of /FigWebServices/anno_server.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Tue Sep 27 22:00:19 2011 UTC (8 years, 3 months ago) by olson
CVS Tags: HEAD, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.16: +18 -424 lines
Diff to previous 1.16
Move inline code out of anno_server.cgi to ANNO.pm (well the code was already moved; remove
the inline invocations).
Add tests.
Thu Oct 28 19:12:56 2010 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.15: +66 -0 lines
kmer dataset querying changes
Mon Sep 20 16:34:05 2010 UTC (9 years, 4 months ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.14: +2 -1 lines
Add -determineFamily and -returnFamilySims to allowed arguments list for assign_function_to_prot
Thu Aug 26 22:03:32 2010 UTC (9 years, 4 months ago) by parrello
Changes since 1.13: +1 -16 lines
Updates for the excel stuff.
Wed Aug 25 15:48:47 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: rast_rel_2010_0827
Added support for small DNA function service.
Thu Jun 3 15:30:49 2010 UTC (9 years, 7 months ago) by olson
fix end-of-service bug
Fri Apr 16 21:37:09 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0526
Push down default max requests.
Wed Apr 14 20:52:22 2010 UTC (9 years, 9 months ago) by olson
Changes since 1.9: +3 -1 lines
use the blast db that goes with the selected release
Thu Mar 25 16:04:56 2010 UTC (9 years, 9 months ago) by parrello
Changes since 1.8: +38 -15 lines
Updates for glimmer training and special-protein finder.
Mon Mar 1 21:09:41 2010 UTC (9 years, 10 months ago) by olson
Changes since 1.7: +0 -1 lines
wup, remove debugging die.
Mon Mar 1 20:58:56 2010 UTC (9 years, 10 months ago) by olson
Changes since 1.6: +82 -6 lines
Support multiple datasets.
Fri Feb 19 17:39:57 2010 UTC (9 years, 11 months ago) by olson
Change to make protein assignment return all ids even with -assignToAll not set; so we can tell
explicitly what IDs did not get assignments.
Tue Dec 22 21:16:19 2009 UTC (10 years ago) by olson
CVS Tags: rast_rel_2010_0118
fix corner case on -assignToAll
Fri Dec 18 16:53:24 2009 UTC (10 years, 1 month ago) by olson
Changes since 1.3: +7 -7 lines
remove debugging
Fri Dec 11 20:49:27 2009 UTC (10 years, 1 month ago) by olson
Changes since 1.2: +4 -8 lines
Add support for using ServerThing to redirect any non-locally-handled functions to ANNO.pm
Thu Dec 10 22:45:53 2009 UTC (10 years, 1 month ago) by olson
Changes since 1.1: +4 -1 lines
clear PERL5LIB before running trna finder
Thu Dec 10 19:38:35 2009 UTC (10 years, 1 month ago) by olson
annotation support server
