[Bio] / FigWebServices / align_and_tree.cgi Repository:
Log of /FigWebServices/align_and_tree.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Mon Dec 5 00:06:52 2011 UTC (8 years, 2 months ago) by golsen
CVS Tags: HEAD, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Fix issue with user name under the SEED.
Revision 1.5 - (view) (download) (annotate) - [selected]
Mon Nov 21 19:43:34 2011 UTC (8 years, 3 months ago) by golsen
Changes since 1.4: +0 -2 lines
Minor changes.
Sun Nov 20 01:29:59 2011 UTC (8 years, 3 months ago) by golsen
Changes since 1.3: +15 -1005 lines
Minor improvements in the classic SEED wrapper.
Mon Nov 14 01:44:00 2011 UTC (8 years, 3 months ago) by golsen
Changes since 1.2: +686 -434 lines
Much new functionality.
Sat Nov 12 00:01:44 2011 UTC (8 years, 3 months ago) by golsen
Changes since 1.1: +47 -61 lines
First running version.
Fri Nov 11 00:21:14 2011 UTC (8 years, 3 months ago) by golsen
Diff to selected 1.5
Initial inferface to Sapling alignments and trees.
