[Bio] / FigWebServices / align_DNA.cgi Repository:
View of /FigWebServices/align_DNA.cgi
Revision 1.3 - (download) (annotate)
Mon Oct 3 13:13:08 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.2: +7 -7 lines
minor fixes to align_DNA.cgi
# -*- perl -*-
use URI::Escape;  # uri_escape()
use HTML;
use strict;
use tree_utilities;
use CGI;
my $cgi = new CGI;
if (0)
    my $VAR1;
    eval(join("",`cat /tmp/align_dna_parms`));
    $cgi = $VAR1;
    print STDERR &Dumper($cgi);
if (0)
    print $cgi->header;
    my @params = $cgi->param;
    print "<pre>\n";
    foreach $_ (@params)
	print "$_\t:",join(",",$cgi->param($_)),":\n";
    if (0)
	if (open(TMP,">/tmp/align_dna_parms"))
	    print TMP &Dumper($cgi);
	    close(TMP);
    exit;
use FIG;
my $fig = new FIG;
my $html = [];
push @$html, "<TITLE>SEED Align DNA</TITLE>\n";
# parameters: @ids        = $cgi->param('peg')        are the ids of the relevant PEGs
#             $upstream   = $cgi->param('upstream')   # of characters upstream (default = 0)
#             $gene       = $cgi->param('gene')       # of characters of gene (defaults to all)
my $upstream   = $cgi->param('upstream');
$upstream      = $upstream ? $upstream : 0;
my $gene       = $cgi->param('gene');
my @pegs       = $cgi->param('peg');
my $seqF = "$FIG_Config::temp/dna$$.fasta";
open(SEQ,">$seqF") || die "could not open $seqF";
my $peg;
my $n = 0;
my %data_per_seq;
foreach $peg (@pegs)
    my($coding,$location);
    $location = $fig->feature_location($peg);
    my($contig,$beg,$end) = $fig->boundaries_of($location);
    if ((! defined($gene)) || ($gene !~ /^\d+/))
	$coding = $fig->dna_seq(&FIG::genome_of($peg),$location)
    elsif ($gene > 0)
	$coding = substr($fig->dna_seq(&FIG::genome_of($peg),$location),0,$gene);
    else
	$coding = "";
    my $trans;
    if ((length($coding) > 2) && $cgi->param('Show With Translation'))
	$trans = $fig->get_translation($peg);
    else
	$trans = "";
    my $upstream_seq = "";
    if ($upstream)
	$upstream_seq = $fig->upstream_of($peg,$upstream,0);
    my $seq = $upstream_seq . $coding;
    print SEQ ">$peg\n$seq\n";
    $data_per_seq{$peg} = [0,$beg,($beg < $end) ? '+' : '-',length($upstream_seq),$trans];
    $n++;
close(SEQ);
if ($n > 1)
    push(@$html,$cgi->start_form(-action => "align_DNA.cgi",
			         -method => 'post'),
	        $cgi->hidden(-name => 'peg', -value => [@pegs], -override => 1),
	        $cgi->param('Show With Translation') ? $cgi->submit('Show Without Translation')
	                                        : $cgi->submit('Show With Translation'),
                $cgi->br,$cgi->br,$cgi->br,
	        "&nbsp;","&nbsp;","Size upstream: ",
	        $cgi->textfield(-name => 'upstream', -size => 4, -value => $upstream),
	        "&nbsp;","&nbsp;",
	        "&nbsp;","&nbsp;", "Restrict coding area to (optional): ",
	        $cgi->textfield(-name => 'gene',   -size => 4, -value => $gene),
    $/ = "\n>";
    my @tmp = `$FIG_Config::bin/align_fasta < $seqF`;
    my($ln,@pegs);
    while (defined($_ = shift @tmp))
	chomp;
	if ($_ =~ /^>?(\S+)[^\n]*\n(.*)/s)
	    my $peg  =  $1;
	    my $seq =  $2;
	    $seq =~ s/\s//gs;
	    push(@{$data_per_seq{$peg}},$seq);
	    if (! $ln) { $ln = length($seq) }
	    push(@pegs,$peg);
    if (@pegs < 2)
	push(@$html,$cgi->h1('Too few sequences or alignment failure'));
    else
	my $i=0;
	for ($i=0; ($i < $ln); $i += 50)
	    &process_one_block($fig,$cgi,$html,\@pegs,$i,($i < ($ln-50)) ? 50 : ($ln - $i),\%data_per_seq);
	    push(@$html,$cgi->br,$cgi->br,$cgi->br,$cgi->br);
else
    push(@$html,$cgi->h1("Less than 2 sequences defined -- alignment failed"));
#unlink $seqF;
&HTML::show_page($cgi, $html);
sub process_one_block {
    my($fig,$cgi,$html,$pegs,$i,$n,$data_per_seq) = @_;
    my($peg,@coding,$j);
    push(@$html,"<table border>\n");
    foreach $peg (@$pegs)
	my $data = $data_per_seq->{$peg};
	my($offset,$beg,$strand,$upstream_left,$translation,$seq) = @$data;
	my $position = ($strand eq "+") ? $beg+$offset-$upstream_left : $beg+$upstream_left-$offset;
	push(@$html,"<tr><td>$peg/$position</td>\n");
	if ($cgi->param('Show With Translation'))
	    @coding = ("<tr><td>coding</td>");
	else
	    @coding = ();
	for ($j=0; ($j < $n); $j++)
	    my $c = substr($seq,$i+$j,1);
	    my $color = "";
	    if     ($c =~ /a/i)        { $color = 'red' }
	    elsif  ($c =~ /c/i)        { $color = 'green' }
	    elsif  ($c =~ /g/i)        { $color = 'blue' }
	    elsif  ($c =~ /[tu]/i)     { $color = 'yellow' }
	    if ($c !~ /-/)
		if ($upstream_left)
		    $upstream_left--;
		    $data->[3] = $upstream_left;
			push(@coding,"<td> </td>\n");
		else
			my($p);
			if (($offset % 3) == 0)
			    $p = substr($translation,$offset / 3,1);
			else
			    $p = " ";
			push(@coding,"<td>$p</td>\n");
		    $data->[0]++;
		    $offset++;
	    push(@$html,"<td bgcolor=$color>$c</td>\n");
	push(@$html,"</tr>\n");
	    push(@coding,"</tr>\n");
	    push(@$html,@coding);
    push(@$html,"</table>\n");
    $/ = "\n";
