[Bio] / FigWebServices / aliases_to_pubmed.cgi Repository:
Log of /FigWebServices/aliases_to_pubmed.cgi
Links to mgrast_rel_2008_0625: (view) (download) (annotate)
Tue Mar 20 18:15:29 2007 UTC (12 years, 8 months ago) by hwang
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.7: +3 -3 lines
Add in routines that save the attributes to ROLE_FROM_PEG_CURATED_RELEVANT
Tue Jan 16 23:34:26 2007 UTC (12 years, 10 months ago) by hwang
add get_attribute(PUBMED)
Tue Jan 16 23:11:48 2007 UTC (12 years, 10 months ago) by hwang
Changes since 1.5: +3 -2 lines
Change code to use Bruce's new attribute server-get_attribute
Tue Nov 28 20:11:41 2006 UTC (13 years ago) by hwang
Changes since 1.4: +142 -107 lines
Changed curation of attributes since there is now an attribute server.
Changed code to allow functional roles to access attributes
Tue Sep 12 18:58:32 2006 UTC (13 years, 3 months ago) by hwang
Took out an image reference that doesn't exist
Tue Sep 12 18:07:05 2006 UTC (13 years, 3 months ago) by hwang
Changes since 1.2: +24 -3 lines
Added PMID attributes  to the journals returned.
Fri Sep 8 20:37:15 2006 UTC (13 years, 3 months ago) by hwang
Changes since 1.1: +76 -28 lines
Improve the instrunctions of curating journals
Fri Aug 18 16:01:53 2006 UTC (13 years, 3 months ago) by hwang
Aliases are given pubmed. Allows curator to drag and drop and add his/her own pubmed journals
