[Bio] / FigWebServices / SimPieces.cgi Repository:
Log of /FigWebServices/SimPieces.cgi
Links to mgrast_rel_2008_0806: (view) (download) (annotate)
Tue Apr 29 08:18:58 2008 UTC (12 years, 1 month ago) by parrello
Fixed. Deprecated ScriptSetup methods are no longer exported by Tracer.
Thu Dec 6 14:28:53 2007 UTC (12 years, 6 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.3: +6 -6 lines
Tue Apr 10 04:07:45 2007 UTC (13 years, 1 month ago) by parrello
Converted DBObject to ERDBObject for Seed Viewer compatability.
Fri Jan 13 06:58:02 2006 UTC (14 years, 4 months ago) by parrello
Updated to display the block name instead of the ID in the piece list.
Wed Jan 11 19:37:28 2006 UTC (14 years, 4 months ago) by parrello
Updated to use new Tracer utilities for scripts.
