[Bio] / FigWebServices / SimPieces.cgi Repository:
Log of /FigWebServices/SimPieces.cgi
Links to caBIG-05Apr06-00: (view) (download) (annotate)
Fri Jan 13 06:58:02 2006 UTC (14 years, 4 months ago) by parrello
Updated to display the block name instead of the ID in the piece list.
Wed Jan 11 19:37:28 2006 UTC (14 years, 4 months ago) by parrello
Updated to use new Tracer utilities for scripts.
