[Bio] / FigWebServices / SimPieces.cgi Repository:
View of /FigWebServices/SimPieces.cgi
Revision 1.1 - (download) (annotate)
Wed Jan 11 19:37:28 2006 UTC (14 years, 6 months ago) by parrello
Updated to use new Tracer utilities for scripts.
#!/usr/bin/perl -w
# Public License.
BEGIN {
    # Print the HTML header.
    print "CONTENT-TYPE: text/html\n\n";
=head1 Similarity Block Piece Display
This script processes input from the C<SimBlockForm.cgi> script's web page and
produces a list of similarity block pieces that are within a specified distance
if the specified feature.
For debugging purposes, you can specify the B<Trace> parameter to
set the tracing level. So, for example,
C<< http://myseedurl/CGI/SimPieces.cgi?Trace=3 >>
runs the standard processing script at a trace level of 3. Normally, only the
script itself and B<Tracer> tracing is active; however, you can activate other tracing modules
by appending them to the trace level. Thus,
C<< http://myseedurl/CGI/SimPieces.cgi?Trace=3%20SimBlocks%20DBObject >>
activates tracing for the similarity block module (C<SimBlocks.pm>) and the data
base object (C<DBObject.pm>).
=cut
use strict;
use CGI;
use Tracer;
use PageBuilder;
use SimBlocks;
# Set up this script.
my ($query, $varHash) = ScriptSetup();
# Do this next part safely.
eval {
    # Get the incoming feature ID and the distance.
    my $featureID = $query->param("Feature");
    my $distance = $query->param("Distance");
    $varHash->{distance} = $distance;
    $varHash->{source} = $featureID;
    # Get the similarity block and FIG objects.
    my $fig = FIG->new();
    my $simdb = SimBlocks->new();
    # Get the list of pieces.
    my @pieces = $simdb->GetFeatureBlockPieces($fig, [$featureID], $distance);
    # Now we build the rows into a single string using the SimBlockPiecesFragment
    # template.
    my $template = Tracer::GetFile("Html/SimBlockPiecesFragment.html");
    my $rows = "";
    for my $piece (@pieces) {
        $rows .= PageBuilder::Build($template,
                                    { blockID => $piece->Contig,
                                      start => $piece->Left,
                                      end => $piece->Right,
                                      len => $piece->Length },
                                    "Html");
    # Put all this data into the variable hash.
    $varHash->{rows} = $rows;
# Check for an error from the EVAL.
if ($@) {
    Trace("Script error: $@") if T(0);
ScriptFinish("Html/SimBlockPieces.html", $varHash);
1;
