[Bio] / FigWebServices / SimBlockPattern.cgi Repository:
Log of /FigWebServices/SimBlockPattern.cgi
Links to rast_rel_2010_0118: (view) (download) (annotate)
Tue Apr 29 08:18:58 2008 UTC (11 years, 11 months ago) by parrello
Fixed. Deprecated ScriptSetup methods are no longer exported by Tracer.
Thu Dec 6 14:28:53 2007 UTC (12 years, 4 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Tue Apr 10 04:07:45 2007 UTC (13 years ago) by parrello
Converted DBObject to ERDBObject for Seed Viewer compatability.
Fri Jul 28 02:07:28 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.4: +3 -3 lines
Changed to use the new PageBuilder call signature.
Wed Jan 11 19:37:28 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.3: +35 -43 lines
Updated to use new Tracer utilities for scripts.
Mon Dec 5 19:12:11 2005 UTC (14 years, 4 months ago) by olson
add license words
Fri Jun 10 06:21:14 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.1: +37 -9 lines
Converted code to use set0 and set1 instead of set1 and set2, so that the names match the list indices.
Wed May 4 03:17:43 2005 UTC (14 years, 11 months ago) by parrello
