[Bio] / FigWebServices / ShowTableFile.cgi Repository:
Log of /FigWebServices/ShowTableFile.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Tue Apr 29 08:16:02 2008 UTC (11 years, 9 months ago) by parrello
Fixed. Deprecated ScriptSetup methods are no longer exported by Tracer.
Tue Oct 10 16:04:45 2006 UTC (13 years, 4 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Fixed to use a local template rather than an NMPDR template. This enables the scripts to run on machines that are not configured for NMPDR.
Tue Oct 10 00:24:18 2006 UTC (13 years, 4 months ago) by parrello
Added to provide a user-friendly listing of TBL files.
