[Bio] / FigWebServices / ShowPage.cgi Repository:
Diff of /FigWebServices/ShowPage.cgi
revision 1.1, Fri Jan 21 15:56:19 2005 UTC revision 1.2, Mon Dec 5 19:12:11 2005 UTC
# Line 1  Line 1
1  #!/usr/bin/perl -w  #!/usr/bin/perl -w
2    #
3    # Copyright (c) 2003-2006 University of Chicago and Fellowship
4    # for Interpretations of Genomes. All Rights Reserved.
5    #
6    # This file is part of the SEED Toolkit.
7    #
8    # The SEED Toolkit is free software. You can redistribute
9    # it and/or modify it under the terms of the SEED Toolkit
10    # Public License.
11    #
12    # You should have received a copy of the SEED Toolkit Public License
13    # along with this program; if not write to the University of Chicago
14    # at info@ci.uchicago.edu or the Fellowship for Interpretation of
15    # Genomes at veronika@thefig.info or download a copy from
16    # http://www.theseed.org/LICENSE.TXT.
17    #
18
19
20  # This module simply displays a page. The page location is given by the directory location  # This module simply displays a page. The page location is given by the directory location
21  # in the form variable "Path", and the file name in the form variable "DocMenu".  # in the form variable "Path", and the file name in the form variable "DocMenu".
Legend:
Removed from v.1.1
changed lines
  Added in v.1.2
