[Bio] / FigWebServices / SetPassword.cgi Repository:
Log of /FigWebServices/SetPassword.cgi
Links to rast_release_2008_09_29: (view) (download) (annotate)
Thu Dec 6 14:28:53 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.10: +5 -5 lines
Thu Jul 26 19:34:25 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.9: +0 -4 lines
Removed the dependence on Sprout so that the program can run on non-Sprout SEEDs.
Tue Apr 10 04:06:23 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.8: +2 -2 lines
Updated some documentation.
Tue Oct 10 15:30:33 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.7: +5 -4 lines
Fixed a bad domain setting on the tracing key cookie.
Tue Oct 3 02:59:38 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.6: +9 -4 lines
Fixed a bug in the tracing key.
Mon Oct 2 06:34:24 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.5: +7 -2 lines
Mon Oct 2 04:42:47 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.4: +10 -7 lines
IPs are too fluid, so the emergency tracing now uses cookies.
Mon Dec 5 19:12:11 2005 UTC (14 years, 2 months ago) by olson
add license words
Thu Sep 15 14:36:05 2005 UTC (14 years, 5 months ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.2: +3 -1 lines
Enhanced to allow specification of a different documentation set.
Tue Aug 16 21:38:08 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.1: +2 -6 lines
Updated to send user directly to SetObject page.
Tue Aug 16 20:31:25 2005 UTC (14 years, 6 months ago) by parrello
Redesigned the Sprout test forms to make the documentation display more robust and to jettison the complicated and only marginally useful method test page.
