[Bio] / FigWebServices / SearchSkeleton.cgi Repository:
Log of /FigWebServices/SearchSkeleton.cgi
Links to rast_rel_2014_0729: (view) (download) (annotate)
Revision 1.31 - (view) (download) (annotate) - [select for diffs]
Wed Sep 3 20:36:36 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.30: +11 -965 lines
Diff to previous 1.30
Converted to work correctly with the wiki.
Revision 1.30 - (view) (download) (annotate) - [select for diffs]
Fri May 16 08:36:04 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: mgrast_rel_2008_0806, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_08_07
Changes since 1.29: +3 -0 lines
Diff to previous 1.29
Added bot tracking.
Revision 1.29 - (view) (download) (annotate) - [select for diffs]
Tue Apr 29 08:13:59 2008 UTC (11 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_07_21
Changes since 1.28: +11 -5 lines
Diff to previous 1.28
Changed to hide the property search from the master list.
Revision 1.28 - (view) (download) (annotate) - [select for diffs]
Thu Dec 6 14:26:47 2007 UTC (12 years, 3 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.27: +13 -13 lines
Diff to previous 1.27
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Mon Aug 20 23:10:47 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.26: +8 -13 lines
Diff to previous 1.26
Added trace messages. Made FidSearch a synonym for GeneSearch. Converted the download options from a list to a table.
Sun Jul 22 18:54:26 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.25: +1 -8 lines
Diff to previous 1.25
Moved EOL computation to FIGRules.
Mon Jul 16 19:49:28 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.24: +163 -257 lines
Diff to previous 1.24
Upgraded to version 2 search technology.
Tue Jun 19 21:20:37 2007 UTC (12 years, 9 months ago) by parrello
Diff to previous 1.23
Added tracing.
Thu May 17 23:38:24 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.22: +66 -26 lines
Diff to previous 1.22
Fixed an error in the non-feature code.
Sat May 5 02:21:12 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.21: +13 -6 lines
Diff to previous 1.21
Changed so that download types can be configured by search type. Added better support for non-Feature searches.
Thu Apr 19 00:03:37 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.20: +1 -0 lines
Diff to previous 1.20
Added support for operon search.
Sat Apr 14 21:42:07 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.19: +133 -29 lines
Diff to previous 1.19
Added support for FASTA downloads.
Tue Apr 10 04:03:05 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.18: +361 -57 lines
Diff to previous 1.18
Modified so that during long searches progress can be seen by the user.
Wed Feb 21 13:14:05 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.17: +8 -2 lines
Diff to previous 1.17
Fixed so that there is no table of contents if there is only one advanced search module.
Fri Feb 9 22:57:31 2007 UTC (13 years, 1 month ago) by parrello
Diff to previous 1.16
Fixed a bug leftover from the old ENTER key fix.
Wed Dec 20 20:08:27 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.15: +6 -8 lines
Changed so that a search is performed if no results exist and the user pressed ENTER instead of clicking the search button.
Wed Dec 6 03:33:52 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.14: +2 -0 lines
Added tracing.
Mon Nov 20 05:54:35 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.13: +29 -8 lines
Upgraded so that the search parameters are preserved by the page navigator.
Sat Nov 18 20:21:26 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.12: +10 -1 lines
Added a table of contents to the advanced search page.
Wed Nov 15 19:57:32 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.11: +25 -3 lines
Added advanced mode and subsystem search.
Fri Nov 10 22:02:40 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.10: +6 -2 lines
Changed the handling of the advanced class list so that it is no longer necessary to maintain a list of search helpers.
Added support for an ADVANCED button.
Wed Nov 8 23:15:38 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.9: +18 -14 lines
Changed results to odd-even blue-white table format.
Thu Oct 19 02:01:12 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.8: +2 -0 lines
Added property search.
Mon Oct 16 07:38:12 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.7: +1 -0 lines
Added support for the new Word Search module.
Sat Oct 14 18:05:03 2006 UTC (13 years, 5 months ago) by parrello
Fixed a comment.
Sat Oct 7 13:23:10 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.5: +7 -5 lines
Fixed backpointers in the navigator. Added more tracing.
Fri Oct 6 23:22:11 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.4: +18 -7 lines
Changed to fix a problem in the way configuration overrides are processed.
Mon Oct 2 03:07:54 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.3: +51 -39 lines
Added more tracing. Improved the page navigator.
Fri Sep 29 15:02:43 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.2: +67 -18 lines
Added the ability to display a URL for the query. Cleaned up handling of help text.
Wed Sep 27 16:57:24 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.1: +24 -12 lines
First round of the search overhaul.
Tue Sep 26 13:41:00 2006 UTC (13 years, 6 months ago) by parrello
New search script.
