[Bio] / FigWebServices / ProcessTemplate.cgi Repository:
Log of /FigWebServices/ProcessTemplate.cgi
Links to mgrast_version_3_2: (view) (download) (annotate)
Tue Apr 29 08:07:45 2008 UTC (11 years, 7 months ago) by parrello
Fixed. Deprecated ScriptSetup methods are no longer exported by Tracer.
Thu Dec 6 14:26:02 2007 UTC (12 years ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.3: +11 -0 lines
Added support for module descriptions.
Tue Nov 6 13:54:12 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.2: +48 -19 lines
General cleanup of the code.
Sat May 5 02:19:38 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.1: +9 -7 lines
Changed to download the generated file instead of displaying it.
Wed Feb 21 13:14:36 2007 UTC (12 years, 9 months ago) by parrello
Fixed the default style URL.
