[Bio] / FigWebServices / Makefile Repository:
View of /FigWebServices/Makefile
Revision 1.18 - (download) (annotate)
Thu Jul 26 19:33:31 2007 UTC (12 years, 8 months ago) by parrello
CVS Tags: rast_rel_2008_06_18, rast_rel_2008_06_16, rast_rel_2008_12_18, rast_rel_2008_07_21, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_09_30, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, mgrast_rel_2008_0625, rast_rel_2008_10_09, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, mgrast_rel_2008_1110, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_08_07
Changes since 1.17: +5 -5 lines
# Public License.
# seed_running_perl.fragement is the piece of perl code that
# checks to see if the seed server is up, and prints a message and returns
# if it is not.
SEED_RUNNING_PERL = seed_running_perl.fragment
PERLCGISCRIPTS := $(subst .pl,,$(wildcard *.cgi))
PERL_LIB = \
	SeedComponents.pm \
	SeedComponents/Basic.pm \
	SeedComponents/Framework.pm \
	SeedComponents/Protein.pm \
	SeedComponents/PubMed.pm \
	WebApplicationComponents.pm \
	WebApplicationComponents/List.pm \
	WebApplicationComponents/Menu.pm \
	WebApplicationComponents/Table.pm \
	WebApplicationComponents/Table2.pm \
	WebApplicationComponents/Table3.pm \
	WebApplicationComponents/Tabulator.pm
INST_PERL_LIB = $(foreach var, $(PERL_LIB), $(libdir)/$(PKGNAME)/$(var))
all: lib
show:
	@echo cgis $(foreach var, $(PERLCGISCRIPTS), $(cgidir)/$(var))
	@echo top $(TOPDIR)
	@echo pkg $(PKGNAME)
	@echo toolhdr $(TOOL_HDR)
bin:
lib:	$(foreach var, $(PERLCGISCRIPTS), $(cgidir)/$(var)) copy_htaccess $(INST_PERL_LIB)
htaccess_src = $(RTROOT)/config/all.htaccess
htaccess_dst = $(cgidir)/.htaccess
copy_htaccess: force
	if test -f $(htaccess_src); then \
		 cp $(htaccess_src) $(htaccess_dst) ; \
	fi
force:
schematools:
stDeclFiles:
stGeneratedFiles:
test:
clean:
# Explicitly build the seed-ctl cgi so that it doesn't include the running check;
# need to be able to run the control panel when the seed is down.
$(cgidir)/seed_ctl.cgi: $(TOPDIR)/$(PKGNAME)/seed_ctl.cgi $(TOOL_HDR)
	( cat $(TOOL_HDR) $< > $@; chmod +x $@ )
$(cgidir)/%: $(TOPDIR)/$(PKGNAME)/% $(TOOL_HDR) $(SEED_RUNNING_PERL)
	( cat $(TOOL_HDR) $(SEED_RUNNING_PERL) $< > $@; chmod +x $@ )
# We have a config problem at the moment.  I do not want to depend
# upon explicit calls to other packages, as done here nor do I want
# to assume that package was built first.  For now, we live with this.
#$(TOOL_HDR):
#	cd $(workdir); $(TOPDIR)/FigCommon/configure-env $(RTARCH) $(TOPDIR)
# Since our lib files have directories, need to create the target
# directory if it doesn't yet exist.
$(libdir)/$(PKGNAME)/%.pm: $(TOPDIR)/$(PKGNAME)/%.pm
	tgt_dir=`dirname $@`;  \
	if [ ! -d $$tgt_dir ] ; then \
		mkdir $$tgt_dir; \
	fi
	cp  $< $@
